Cheap big-endian board
Andrei Chichak
groups at chichak.ca
Fri Aug 3 20:45:35 UTC 2012
On 2012-August-03, at 2:26 PM, Mathew Benson wrote:
> Yes, I preferred PowerPC but didn't find anything even close to my budget so I considered all PowerPC out.
There is always the Freescale TRK-MPC5642M which uses an MPC5634M powerpc chip for embedded automotive applications … scratch that, you needed cheap and fast. This board is $99 but only runs at 80MHz., on the other hand it does have a built in debugger and an eTPU for timing critical pulse generation stuff. You would also have to adapt an existing BSP.
How about an off the shelf PC and use the Pc386 BSP? Cheap - yep, fast as you need - should do, lots of I/O - err not really, well documented - depends.
A
URL: <http://lists.rtems.org/pipermail/users/attachments/20120803/8e91f224/attachment.html>
