Simulator for MPC5200
Steven Grunza
sgrunza at ctdi.com
Tue Aug 7 12:49:12 UTC 2012
Looks like you tried to configure within the qemu source directory. I
usually build in a separate directory.
mkdir b-qemu
cd b-qemu
../qemu.git/configure --target-list="ppc-softmmu"
--prefix=/usr/local/bin
Install prefix /usr/local/bin
BIOS directory /usr/local/bin/share/qemu
binary directory /usr/local/bin/bin
library directory /usr/local/bin/lib
include directory /usr/local/bin/include
config directory /usr/local/bin/etc
Manual directory /usr/local/bin/share/man
ELF interp prefix /usr/gnemul/qemu-%M
Source path /home/grunzasr/qemu.git
C compiler gcc
Host C compiler gcc
CFLAGS -O2 -D_FORTIFY_SOURCE=2 -g
QEMU_CFLAGS -fPIE -DPIE -m64 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64
-D_LARGEFILE_SOURCE -Wstrict-prototypes -Wredundant-decls -Wall -Wundef
-Wwrite-strings -Wmissing-prototypes -fno-strict-aliasing -Werror
-fstack-protector-all -Wendif-labels -Wmissing-include-dirs
-Wnested-externs
-Wformat-security -Wformat-y2k -Winit-self -Wold-style-definition
-I/usr/include/libpng12
LDFLAGS -Wl,--warn-common -Wl,-z,relro -Wl,-z,now -pie -m64 -g
make make
install install
python python
smbd /usr/sbin/smbd
host CPU x86_64
host big endian no
target list ppc-softmmu
tcg debug enabled no
Mon debug enabled no
gprof enabled no
sparse enabled no
strip binaries yes
profiler no
static build no
-Werror enabled yes
SDL support yes
curses support yes
curl support no
mingw32 support no
Audio drivers oss
Extra audio cards ac97 es1370 sb16 hda
Block whitelist
Mixer emulation no
VirtFS support no
VNC support yes
VNC TLS support no
VNC SASL support no
VNC JPEG support yes
VNC PNG support yes
xen support no
brlapi support no
bluez support no
Documentation yes
NPTL support yes
GUEST_BASE yes
PIE yes
vde support no
Linux AIO support no
ATTR/XATTR support yes
Install blobs yes
KVM support yes
TCG interpreter no
fdt support no
preadv support no
fdatasync yes
madvise yes
posix_madvise yes
uuid support no
libcap-ng support no
vhost-net support yes
Trace backend nop
Trace output file trace-<pid>
spice support no
rbd support no
xfsctl support no
nss used no
usb net redir no
OpenGL support yes
libiscsi support no
build guest agent yes
coroutine backend ucontext
grunzasr at stm32dbg% ls -FC
config-host.ld config.log libdis/ libhw32/ libuser/
Makefile@ ppc-softmmu/ qdict-test-data.txt@ roms/
config-host.mak libcacard/ libdis-user/ libhw64/ linux-headers/
pc-bios/ qapi-generated/ QMP/ tests/
I don't know if the code will build but the "make" is currently
running...
[mailto:rtems-users-bounces at rtems.org] On Behalf Of Binkowski, Cassio
Sent: Tuesday, August 07, 2012 6:54 AM
To: Joel Sherrill
Cc: rtems-users at rtems.org
Subject: Re: Simulator for MPC5200
Ok. Downloaded the tools.
I'm trying to build Qemu for PowerPC now. I run the following line, as I
found in the Notes file inside QEMU directory:
./configure --target-list="ppc-softmmu"
--prefix=/home/rtems/qemu/install >c.log 2>&1 ; echo $?
... and get this:
head: cannot open `/root/Desktop/rtems\'' for reading: No such file or
directory
head: cannot open `Home/qemu/qemu/VERSION' for reading: No such file or
directory
ln: creating symbolic link `Home/qemu/qemu/Makefile.dis': No such file
or directory
or directory
ln: creating symbolic link `Home/qemu/qemu/linux-headers/asm-x86': No
such file or directory
ln: creating symbolic link `Home/qemu/qemu/Makefile.target': No such
file or directory
ln: creating symbolic link `Home/qemu/qemu/Makefile.hw': No such file or
directory
directory
./configure: line 3876: [: too many arguments
ln: creating symbolic link `Home/qemu/qemu/Makefile.user': No such file
or directory
Has anyone had this before?
Best regards
URL: <http://lists.rtems.org/pipermail/users/attachments/20120807/aaa8c64f/attachment.html>
