maintaining BSP that isnt in an RTEMS production release
Hill, Jeff
johill at lanl.gov
Fri Aug 10 17:20:22 UTC 2012
> can you please remove all
> #if ( __RTEMS_MAJOR__ > 4 ) || \
> ( __RTEMS_MAJOR__ == 4 && __RTEMS_MINOR__ > 10 ) || \
> ( __RTEMS_MAJOR__ == 4 && __RTEMS_MINOR__ == 10 && __RTEMS_REVISION__ >= 99 )
Here is how I decided to have a special case for this type of ifdef
1) Nios2 isn't included in a production release of RTEMS
2) We will soon use RTEMS/Nios2 in a production installation
3) Currently I have to continuously back-patch the RTEMS main
trunk Nios2 patches into the RTEMS 4.10 version and that requires
some continuing effort. It's much easier to maintain a Nios2
support code that works on both in RTEMS 4.10 and also the
main trunk.
Making this type of ifdef work correctly did require some effort;
I am a bit new with the gnu build system.
I am requesting that we use this type of ifdef in the Nios2 specific
code only until such a time that the Nios2 specific code can obtain
a citizen status in RTEMS.
I completely agree that the ifdef should be 100% removed after
Nios2 shows up in a released branch of RTEMS; at that time I
will have two places in git to maintain both the production
version and the main trunk version which will allow a typical
type of develop-quickly-on-the-main-trunk and polish-on-the-
production-branch approach to quality control which is not
currently possible.
This is just a quick check to verify that you are aware
of my concerns. If you still feel the same way after reading
my position then I will comply with your request; I am the
new person in this community after all so I will be happy to
acquiesce in favor of your superior expertise with RTEMS.
Thanks,
Jeff
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Friday, August 10, 2012 9:00 AM
> To: Hill, Jeff
> Subject: Re: FW: FW: rtems on nios2 collaborative efforts
> Hello Jeff,
> +#if ! defined ( __RTEMS_MAJOR__ ) || \
> + ! defined ( __RTEMS_MINOR__ ) || \
> + ! defined ( __RTEMS_REVISION__ )
> +# error __RTEMS_MAJOR__, __RTEMS_MINOR__, and __RTEMS_REVISION__ must
> be defined
> +#endif
> and the like from the patches. The RTEMS sources are supposed to work in
> the
> current version.
> Can you please reformat at least the code in the cpukit to follow the
> RTEMS
> coding style. This is no tabs and two space characters per indentation
> level.
> All global Nios II specific functions should have the form
> _Nios2_Function_name(), types should have the form Nios2_Some_type, and
> constants should have the form NIOS2_SOME_CONSTANT (also enums).
> Please remove all new #if 0 blocks.
> Kind regards,
> Sebastian
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
