ANN: microblaze-rtems4.11 toolchain
Fri Aug 24 22:17:26 UTC 2012
Ralf Corsepius wrote:
> On 08/24/2012 03:30 PM, Joel Sherrill wrote:
>> On 08/24/2012 08:06 AM, Ralf Corsepius wrote:
>>> On 08/24/2012 02:46 PM, Joel Sherrill wrote:
>>>> You only work to support a fragment of the community.
>>> Correct, I have been actively sharing my works on platforms/OSes which I
>>> am technically able to support and I consider support-worthy.
>>>> Don't be a hindrance to those who didn't choose from your list of
>>>> preferred host OSes.
>>> Listen, Dr. Sherrill, while you are in a position to permantently
>>> undermine my works (The works which had kept RTEMS alive throughout the
>>> last decade)
None of us are that critical and if we are the project has a serious
problem.
> you are not in a position to push me around!
If supporting another platforms is undermining your work and then making
a comment in support is pushing you around then I am confused. I would
have thought making us all have to use a RPM based Linux because you
only support those platforms is a case of you dictating to us and the
community what we use.
