Error in Installing Autotools 4.10
Binkowski, Cassio
cassioiks at gmail.com
Thu Feb 23 23:20:51 UTC 2012
Hi everyone,
I was trying to install RTEMS 4.10 but the Autotools install failed.
The last line of code in the setup wizard was the following:
"c:\msys\1.0\bin\sh" --login -c
"C:/opt/rtems-4.10/Packages/Source/ba-wrap.sh -p /opt/rtems-4.10 -b
C:/opt/rtems-4.10/Packages/Build -c
C:/opt/rtems-4.10/Packages/Source/autoconf.def"
Tried to run it manually in MSYS and got the following output:
m.AllocationBase 0x0, m.BaseAddress 0x715B0000, m.RegionSize 0x390000,
m.State 0x10000
C:\msys\1.0\bin\install.exe: *** Couldn't reserve space for cygwin's heap
(0x715B0000 <0x25C0000>) in child, Win32 error 0
m.State 0x10000
(0x715B0000 <0x2680000>) in child, Win32 error 0
Do you have a glimpse on what it might be?
Thanks
Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20120223/35c5bafc/attachment.html>
