Error in Installing Autotools 4.10
Fri Feb 24 04:37:50 UTC 2012
On 24/02/12 10:20 AM, Binkowski, Cassio wrote:
> Hi everyone,
> I was trying to install RTEMS 4.10 but the Autotools install failed.
> The last line of code in the setup wizard was the following:
Which setup wizard are you referring to ?
> "c:\msys\1.0\bin\sh" --login -c
> "C:/opt/rtems-4.10/Packages/Source/ba-wrap.sh  -p /opt/rtems-4.10 -b
> C:/opt/rtems-4.10/Packages/Build -c
> C:/opt/rtems-4.10/Packages/Source/autoconf.def"
> Tried to run it manually in MSYS and got the following output:
> m.AllocationBase 0x0, m.BaseAddress 0x715B0000, m.RegionSize 0x390000,
> m.State 0x10000
> C:\msys\1.0\bin\install.exe: *** Couldn't reserve space for cygwin's
> heap (0x715B0000 <0x25C0000>) in child, Win32 error 0
> m.State 0x10000
> heap (0x715B0000 <0x2680000>) in child, Win32 error 0
> Do you have a glimpse on what it might be?
Is this the latest msys installed by mingw-get ?
