Starting with RTEMS
Binkowski, Cassio
cassioiks at gmail.com
Sun Feb 26 17:36:41 UTC 2012
When I type in the last line required to build RTEMS:
make install
And most of what shows in the prompt screen is:
make[3]: Leaving directory `/opt/rtems-4.11/rtems4.11-build/avr-rtems4.11/c'
make[2]: Leaving directory `/opt/rtems-4.11/rtems4.11-build/avr-rtems4.11/c'
make[1]: Leaving directory `/opt/rtems-4.11/rtems4.11-build/avr-rtems4.11/c'
make[1]: Entering directory `/opt/rtems-4.11/rtems4.11-build'
make[2]: Entering directory `/opt/rtems-4.11/rtems4.11-build'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/opt/rtems-4.11/rtems4.11-build'
make[1]: Leaving directory `/opt/rtems-4.11/rtems4.11-build'
Is it right or not?
P.S: I have bootstrapped it.
On Wed, Feb 22, 2012 at 11:57 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 23/02/12 11:55 AM, Binkowski, Cassio wrote:
>> Oh, I understand.
>> I actually installed RTEMS 4.9, as the wiki said. But the code was 4.10.2.
> The wiki was out of date and the information wrong. The fact it worked was
> just luck.
> I don't think I understand what you mean by tools in the installer, but
>> I used DOS to build it. A few lines to unzip RTEMS and a few more others
>> to /make/ it.
> The tools came in a single executable which is an installer. This is what
> I mean.
> I have uninstalled and erased previous version and downloaded the new
>> one, so I can build it again.
> Great.
> This time, I have downloaded only AVR tools for RTEMS 4.10 installation.
>> But I'm still with the 4.10.2 RTEMS tar. Is that ok?
> Yes this is much much better. The fact 4.10.2 built with the 4.9 tools is
> an accident. I doubt any of the code would have run. The C library would
> have mismatches.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20120226/0aa2c20f/attachment.html>
