RTEMS and 1553 ddc BU 67104 ver 5
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Feb 14 20:13:54 UTC 2012
On 02/14/2012 09:54 AM, Rafael Morales wrote:
> Dear Juan Pablo,
> If I'm not wrong, the libraries of DDC boards are not compatible with
> RTEMS. They have libraries only for linux and windows.
This definitely looks like the code you are linking is missing something
from DDC.
--joel
> Saludos Rafael.
>> Hello my name is Juan Pablo (my English is poor, sorry for that) and I'm
>> working with RTEMS operating system version 4.10 for i386 using device BU67104
>> 1553 ddc version 5 (pc 104).
>> The question is on the following compilation error (linker), copied it below:
>> **** Build of configuration RTEMS_Executable_Configuration for project
>> mon1553_prueba002 ****
>> make all
>> Building file: ../main.c
>> Invoking: RTEMS C Compiler
>> /opt/rtems-4.10/bin/i386-rtems4.10-gcc
>> -B/opt/rtems-4.10/i386-rtems4.10/pc386/lib/ -specs bsp_specs -qrtems
>> -mtune=i386 -Os -g -Wall -c -fmessage-length=0 -pipe -MMD -MP -MF"main.d"
>> -MT"main.d" -o"main.o" "../main.c"
>> ../main.c: In function 'Init':
>> ../main.c:45: warning: 'result' is used uninitialized in this function
>> ../main.c:30: note: 'result' was declared here
>> Finished building: ../main.c
>> Building target: mon1553_prueba002.exe
>> Invoking: RTEMS C++ Linker
>> /opt/rtems-4.10/bin/i386-rtems4.10-g++
>> -mtune=i386 -Wl,-Ttext,0x00100000 -L/opt/rtems-4.10/i386-rtems4.10/pc386/lib
>> -L/opt/rtems-4.10/i386-rtems4.10/pc386/lib/rtems-4.10
>> -L/home/rtems/acextreme/acetoemace/lib/i386 -L/home/rtems/acextreme/lib/i386
>> -L/home/rtems/ddc/Lib/Release -o"mon1553_prueba002.exe" ./ddc1553.o ./main.o
>> -lrtems++ -lace -lemacepl
>> ./main.o: In function `Init':
>> /home/rtems/workspace/mon1553_prueba002/RTEMS_Executable_Configuration/../main.c:45:
>> undefined reference to `ddc1553_initialize'
>> undefined reference to `ddc1553_open'
>> undefined reference to `ddc1553_close'
>> /home/rtems/workspace/mon1553_prueba002/RTEMS_Executable_Configuration/../main.c:47:
>> undefined reference to `ddc1553_read'
>> /home/rtems/workspace/mon1553_prueba002/RTEMS_Executable_Configuration/../main.c:48:
>> undefined reference to `ddc1553_control'
>> collect2: ld returned 1 exit status
>> make: *** [mon1553_prueba002.exe] Error 1
>> using the library libemacepl.a libemacepl.so.3.2.6 (the "includes" routes (.
>> hpp) is made).
>> Apparently not find references to these methods (but all references. Hpp made)
>> with respect to the library in question, can someone tell me
>> is the most convenient to do in these cases?
>> thanks in advance...
>> Generado por el Webmail de la Fuerza Aerea Argentina
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120214/6731fd9d/attachment-0001.html>
