CentOS 6.2 Virtual Machine
Mon Feb 27 06:15:43 UTC 2012
I pushed to get that VM uploaded before I left to come to Germany for Embedded World. It took over 2 hours to upload and I barely got it done in time. I see you emailed me privately with details.
+ qemu is not in PATH or in setenv
+ qemu-system-i386 is now the command name
The first is an oversight on my part. Qemu was an rpm on the old fedora images and I had to build qemu this time.
I think the latter is a change in naming by qemu project. Pc386 script needs to be fixed.
Keep a list of anything else you spot and I will try to fix everything next week when at home. These are time consuming to export and upload. I am glad it was a valid image for you. Last time some people had trouble with different players.
Thanks.
--joel
Paul Crocker <crocker at di.ubi.pt> wrote:
>Hello,
>With respect to the virtual machine centos 6.2
>I think that the installation of qemu is not correct...
>paul crocker
>> Hi,
>> It is close to time for the Google Summer of Code students
>> to start showing up. I have created a CentOS VM with
>> sparc and i386 tools installed. This is the first VM
>> on CentOS and the first since switching to git.
>> Please review this and see if it looks OK
>> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>> Thanks.
>> Joel Sherrill, Ph.D.             Director of Research&   Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>      Support Available             (256) 722-9985
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
>Paul Andrew Crocker  PhD
>email Paul -> crocker#di*ubi*pt
>Departamento de Informática    | http://www.di.ubi.pt/~crocker
>Universidade da Beira Interior | Tel: +351 275 319 891
>Rua Marquês d'Âvila e Bolama   | Fax: +351 275 319 899
>6200-001 Covilhã, PORTUGAL.
>Instituto de Telecomunicações (www.it.pt)
>RELiablE And SEcure computation Group (www.di.ubi.pt/~release)
