Space Qualified RTEMS
Cláudio Silva claudiodcsilva at gmail.com
Tue Jan 24 16:18:56 UTC 2012
Hi,
You will find some of your answers in this paper about the “space
qualified” version of RTEMS:
http://inforum.org.pt/INForum2009/docs/full/paper_88.pdf
The quick version is:
1) "The tailored RTEMS version consists of patches and scripts that,
if applied to the original RTEMS source code, will remove the
unnecessary managers, files, dead code and bugs. It also adds new
files and code, making all necessary code adjustments to produce the
RTEMS tailored version (qualifiable)" [quoted from the article above]
2) No. As you said the toolchain and kernel are based on RTEMS 4.8.
RCC 1.1.99.19 is based on RTEMS 4.10. (at least i think so)
3) N/A
Regards,
Cláudio
On Tue, Jan 24, 2012 at 3:41 PM, Matthews, Lee
<l.matthews at imperial.ac.uk> wrote:
> Hi,
> I’m developing software that uses RTEMS on an Aeroflex Gaisler LEON3FT
> processor that is running on a Pender GR-CPCI-AX2000 development board. I am
> using version 4.10 of RTEMS and RCC 1.1.99.19.
> We are working on producing a Magnetometer instrument that will be
> integrated into ESA’s upcoming Solar Orbiter mission to the Sun. We shall be
> using RTEMS on our Leon3FT CPU. Having just gone through ESA’s Preliminary
> Design Review process, it has been highlighted by ESA that there is a space
> qualified version of RTEMS available, though this is currently based on
> version 4.8 of the kernel. I believe this is being developed by the company
> Edisoft (http://rtemscentre.edisoft.pt).
> I have a few questions about this :
> 1)  Does anyone know what the difference is exactly between a “standard” and
> a “space qualified” version of RTEMS ?
> 2)  Assuming that we were to use the space qualified RTEMS 4.8 kernel, would
> we still be able to use Aeroflex Gaisler’s BSP (RCC 1.1.99.19) ?
> 3)  Would Aeroflex Gaisler’s BSP also need to be space qualified ?
> Thanks in advance.
> Best wishes,
> Lee Matthews
> rtems-users mailing list
> rtems-users at rtems.org
