blackfin how to
Jan Humpl jenikh at centrum.cz
Fri Jan 27 09:33:56 UTC 2012
thanks for reply.
I successfully installed u-boot on BF537 ezkit (thanks uClinux
documentation). Now I don't know what to do now - cause I can't find any
documentation.
So I was tried to convert *.exe file to *.bin with command:
bfin-rtems4.10-objcopy --gap-fill=0xff -O binary ticker.exe ticker.bin
and then I can load this file to memory at address 0x1000. Then I can
run (?? I suppose) the program with "go 0x1000" => but I don't receive
any output on serial port.
I don't know, if that is correct, because I can't find any documentation
- that includes that I don't know, which device is used as standard
output (is it serial port?), is there ETH network running?, is there gdb
server running? Or how to test / debug the software?
I'm trying to find some useful information in source codes, but I can't
find any board specific or CPU specific file with configuration related
to stdout, debug or communication interfaces.
I'll be glad if anyone can help me or give me at least his own story how
to debug first application. Thanks.
JH
On 01/20/12 23:58, Mike Frysinger wrote:
> On Wed, Jan 18, 2012 at 05:54, Jan Humpl wrote:
>> I'm looking for any Blackfin (537 STAMP) "how to". I have RTEMS compiled
>> but I don't know what to do now - which file to load and how to connect
>> to JTAG and load it to CPU. Thanks for help.
> i think you can install u-boot and then have that boot the rtems images
> -mike
