blackfin how to
Mike Frysinger
vapier.adi at gmail.com
Sat Jan 28 05:32:42 UTC 2012
On Fri, Jan 27, 2012 at 01:33, Jan Humpl <jenikh at centrum.cz> wrote:
> I successfully installed u-boot on BF537 ezkit (thanks uClinux
> documentation). Now I don't know what to do now - cause I can't find any
> documentation.
plenty of documentation abounds. you just have to find the right one ;).
> So I was tried to convert *.exe file to *.bin with command:
a .exe is just an ELF. try using "bootelf".
> and then I can load this file to memory at address 0x1000. Then I can
> run (?? I suppose) the program with "go 0x1000" => but I don't receive
> any output on serial port.
> I don't know, if that is correct, because I can't find any documentation
> - that includes that I don't know, which device is used as standard
> output (is it serial port?), is there ETH network running?, is there gdb
> server running? Or how to test / debug the software?
i can't speak to rtems documentation, just u-boot. i've done very
little of the former, but plenty of the latter.
-mike
