Virtualbox RTEMS Setup
Thu Jul 19 16:10:12 UTC 2012
Hi
I know this has been answered before but I don't recall which
answer it is:
(1) qemu is not in your PATH. The qemu installation was
      left out of setting the PATH in the setenv script
(2) It is really called qemu-system-i386 and the script
      needs to use the correct name. qemu renamed this.
-joel
On 07/19/2012 11:02 AM, Aric Hunter wrote:
> Hello,
> I am attempting to get the RTEMS development station setup on the
> Centos virtualbox.
> I was following the instructions on the wiki:
> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
> I got to the section for testing the i386/pc386 without any problems,
> but then I tried to do tho the following command:
>         pc386 -i
> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
> and got this error:
>         /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line 298:
> type: qemu: not found
>         FAILED:  Path appears to be broken (cannot find qemu)
> Any ideas as to what I am missing/doing incorrectly?
> My ultimate goal is to run lm3s6965 instead of pc386, but I get the
> same error with either.
> Thanks,
> Aric Hunter
Joel Sherrill, Ph.D.             Director of Research&   Development
