Virtualbox RTEMS Setup
Thu Jul 19 17:28:53 UTC 2012
On Thu, Jul 19, 2012 at 1:12 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 07/19/2012 12:05 PM, Aric Hunter wrote:
> Fantastic!!!
> I looked into /home/rtems/qemu/install/bin and saw the qemu-system-i386 file
> that you mentioned, and after the update everything with the i386/pc386
> works just fine.
> If you have time:
> How do I get qemu-system-arm?
> Is it as simple as another git update?
> On that virtualbox image, the qemu was pulled from their git
> and built. You just need to do their build and let it build everything.
> I restricted it to i386 for size.
IIRC for lm3sxx there are some patches for qemu in the bsp directory..
not sure if they are still necessary.
> Thanks oodles,
> Aric Hunter
> On Thu, Jul 19, 2012 at 9:27 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On 07/19/2012 11:25 AM, Aric Hunter wrote:
>> I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
>> I haven't tried solution 2.
>> So, for solution 2, somewhere in the pc386 script it attempts to run qemu
>> but it should be qemu-system-i386?
>> Yep.
>> You could update the rtems-testing git module and type make :)
>> ls /home/rtems/qemu/install/bin and see what's there
>> I will look for that.
>> Thanks for the amazingly quick replies,
>> Aric Hunter
>> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> Hi
>>> I know this has been answered before but I don't recall which
>>> answer it is:
>>> (1) qemu is not in your PATH. The qemu installation was
>>>      left out of setting the PATH in the setenv script
>>> (2) It is really called qemu-system-i386 and the script
>>>      needs to use the correct name. qemu renamed this.
>>> -joel
>>> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>>>> Hello,
>>>> I am attempting to get the RTEMS development station setup on the Centos
>>>> virtualbox.
>>>> I was following the instructions on the wiki:
>>>> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>>>> I got to the section for testing the i386/pc386 without any problems,
>>>> but then I tried to do tho the following command:
>>>>         pc386 -i
>>>> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
>>>> and got this error:
>>>>         /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line 298:
>>>> type: qemu: not found
>>>>         FAILED:  Path appears to be broken (cannot find qemu)
>>>> Any ideas as to what I am missing/doing incorrectly?
>>>> My ultimate goal is to run lm3s6965 instead of pc386, but I get the same
>>>> error with either.
>>>> Thanks,
>>>> Aric Hunter
>>> Joel Sherrill, Ph.D.             Director of Research&   Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>     Support Available             (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
