Virtualbox RTEMS Setup
Aric Hunter
aricahunter at gmail.com
Thu Jul 19 21:36:25 UTC 2012
I installed qemu-system-arm and attempted to test the lm3s6965 with a test
file in the pc386 testsuite and got this error.
lm3s6965 -v -i hello.exe
Default program to run is
Using qemu-system-arm
qemu-system-arm is /usr/local/bin/qemu-system-arm
TESTS TO RUN: hello.exe
INTERACTIVE runtest hello.exe single 0
qemu-system-arm -nographic -M lm3s6965evb -kernel hello.exe
qemu: fatal: Bad mode 1c
R00=00000000 R01=0000007f R02=00000000 R03=00000000
R04=00890089 R05=00000000 R06=00000000 R07=00000000
R08=00000000 R09=00000000 R10=00000000 R11=00000000
R12=00000000 R13=464c457f R14=00000000 R15=00010118
PSR=00000173 ---- T svc32
Aborted (core dumped)
what patches are you talking about for lm3s6965?
I see some binpatch files, but not much else.
> On Thu, Jul 19, 2012 at 10:28 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jul 19, 2012 at 1:12 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>> > On 07/19/2012 12:05 PM, Aric Hunter wrote:
>> > Fantastic!!!
>> > I looked into /home/rtems/qemu/install/bin and saw the qemu-system-i386
>> file
>> > that you mentioned, and after the update everything with the i386/pc386
>> > works just fine.
>> > If you have time:
>> > How do I get qemu-system-arm?
>> > Is it as simple as another git update?
>> > On that virtualbox image, the qemu was pulled from their git
>> > and built. You just need to do their build and let it build everything.
>> > I restricted it to i386 for size.
>> IIRC for lm3sxx there are some patches for qemu in the bsp directory..
>> not sure if they are still necessary.
>> > Thanks oodles,
>> > Aric Hunter
>> > On Thu, Jul 19, 2012 at 9:27 AM, Joel Sherrill <
>> > wrote:
>> >> On 07/19/2012 11:25 AM, Aric Hunter wrote:
>> >> I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
>> >> I haven't tried solution 2.
>> >> So, for solution 2, somewhere in the pc386 script it attempts to run
>> qemu
>> >> but it should be qemu-system-i386?
>> >> Yep.
>> >> You could update the rtems-testing git module and type make :)
>> >> ls /home/rtems/qemu/install/bin and see what's there
>> >> I will look for that.
>> >> Thanks for the amazingly quick replies,
>> >> Aric Hunter
>> >> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill <
>> >> wrote:
>> >>> Hi
>> >>> I know this has been answered before but I don't recall which
>> >>> answer it is:
>> >>> (1) qemu is not in your PATH. The qemu installation was
>> >>> left out of setting the PATH in the setenv script
>> >>> (2) It is really called qemu-system-i386 and the script
>> >>> needs to use the correct name. qemu renamed this.
>> >>> -joel
>> >>> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>> >>>> Hello,
>> >>>> I am attempting to get the RTEMS development station setup on the
>> Centos
>> >>>> virtualbox.
>> >>>> I was following the instructions on the wiki:
>> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>> >>>> I got to the section for testing the i386/pc386 without any problems,
>> >>>> but then I tried to do tho the following command:
>> >>>> pc386 -i
>> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
>> >>>> and got this error:
>> >>>> /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line
>> 298:
>> >>>> type: qemu: not found
>> >>>> FAILED: Path appears to be broken (cannot find qemu)
>> >>>> Any ideas as to what I am missing/doing incorrectly?
>> >>>> My ultimate goal is to run lm3s6965 instead of pc386, but I get the
>> same
>> >>>> error with either.
>> >>>> Thanks,
>> >>>> Aric Hunter
>> >>> Joel Sherrill, Ph.D. Director of Research& Development
>> >>> joel.sherrill at OARcorp.com On-Line Applications Research
>> >>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> >>> Support Available (256) 722-9985
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/a1b5c140/attachment.html>
