FW: Accuracy of rtems_timer_server_fire_after
Sebastian Huber
Wed Jul 11 07:13:54 UTC 2012
On 07/10/2012 03:20 PM, Mogens Dybæk Christensen wrote:
> Hello Sebastian
> At first I set the timer server priority to 5. I then tried to give it priority 1 (apparently the highest possible, 0 is not allowed). It changes nothing.
> At least the first shot with rtems_timer_server_fire_after is very slow. - Have no measurements yet for the following ones, but I can add more test code.
You can set a break point to _Thread_Delay_ended() and step to your timer
routine. This should reveal the execution path and show the reason for the delay.
> As mentioned before, delays made with rtems_task_wake_after are more accurate.
> It seems that the main loop in the timer server itself uses a timer to wait before next check/action, but I did not understand it all at first glance. :-)
> The server code is in rtems/cpukit/rtems/src/timerserver.c. How fast (and accurate) is the timer server intended to be,
The timer server works with clock tick granularity for
rtems_timer_server_wake_after() and with seconds granularity for
rtems_timer_server_wake_when(). You should only observe a small delay due to
the task switch once a server timer is triggered.
> and can the prescaling from clock tick to server invocation be changed?
Not easily, this would require some changes in the timer server code.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
