Developing under MacOS
Eric Norum
wenorum at lbl.gov
Sun Jul 15 22:23:21 UTC 2012
Hmm...seems to run here:
ARCHS="m68k i386 powerpc" sh ../getAndBuildTools-4.11.sh
+ getSource
+ curl --remote-name ftp://www.rtems.com/pub/rtems/SOURCES/4.11/binutils-2.22.tar.bz2
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
Everything builds except the PowerPC version of PSIM.
On Jul 15, 2012, at 11:08 AM, Binkowski, Cassio wrote:
> Hi Eric
> Thanks a lot. That's gonna do it, I guess.
> I tried to run the script but all I got was the following:
> : command not found4.11.sh: line 2:
> : command not found4.11.sh: line 6:
> : command not found4.11.sh: line 12:
> : command not found4.11.sh: line 26:
> : command not found4.11.sh: line 31:
> : command not found4.11.sh: line 44:
> : command not found4.11.sh: line 51:
> ': not a valid identifierh: line 56: export: `MAKE
> ': not a valid identifierh: line 58: export: `SHELL
> : command not found4.11.sh: line 59:
> '/getAndBuildTools-4.11.sh: line 66: syntax error near unexpected token `{
> '/getAndBuildTools-4.11.sh: line 66: `getSource() {
> Do you know what it is?
> Also, I does this script download all BSP tools already?
> Thanks a lot for making this Script.
> Best regards
> Cassio
> On Sat, Jul 14, 2012 at 2:21 PM, Eric Norum <wenorum at lbl.gov> wrote:
> Yep.
> I've attached my 'get and build' script.
> Please let me know if this works for you.
> On Jul 14, 2012, at 9:31 AM, Binkowski, Cassio wrote:
> > Hi everyone
> > Has anyone had the experience of developing RTEMS application using MacOS platform?
> > I would like to know if it`s worth the time it takes to build all tools from source instead of just using the VM.
> > Thanks and best regards
> > Cassio
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120715/77695ded/attachment-0001.html>
