Virtualbox RTEMS Setup
Aric Hunter aricahunter at gmail.com
Thu Jul 19 17:05:49 UTC 2012
Fantastic!!!
I looked into /home/rtems/qemu/install/bin and saw the qemu-system-i386
file that you mentioned, and after the update everything with the
i386/pc386 works just fine.
If you have time:
How do I get qemu-system-arm?
Is it as simple as another git update?
Thanks oodles,
Aric Hunter
On Thu, Jul 19, 2012 at 9:27 AM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>  On 07/19/2012 11:25 AM, Aric Hunter wrote:
> I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
> I haven't tried solution 2.
> So, for solution 2, somewhere in the pc386 script it attempts to run qemu
> but it should be qemu-system-i386?
> Yep.
> You could update the rtems-testing git module and type make :)
> ls /home/rtems/qemu/install/bin and see what's there
>  I will look for that.
> Thanks for the amazingly quick replies,
> Aric Hunter
> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>> Hi
>> I know this has been answered before but I don't recall which
>> answer it is:
>> (1) qemu is not in your PATH. The qemu installation was
>>      left out of setting the PATH in the setenv script
>> (2) It is really called qemu-system-i386 and the script
>>      needs to use the correct name. qemu renamed this.
>> -joel
>> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>>> Hello,
>>> I am attempting to get the RTEMS development station setup on the Centos
>>> virtualbox.
>>> I was following the instructions on the wiki:
>>> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>>> I got to the section for testing the i386/pc386 without any problems,
>>> but then I tried to do tho the following command:
>>>         pc386 -i
>>> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
>>> and got this error:
>>>         /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line 298:
>>> type: qemu: not found
>>>         FAILED:  Path appears to be broken (cannot find qemu)
>>> Any ideas as to what I am missing/doing incorrectly?
>>> My ultimate goal is to run lm3s6965 instead of pc386, but I get the same
>>> error with either.
>>> Thanks,
>>> Aric Hunter
>> Joel Sherrill, Ph.D.             Director of Research&   Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>     Support Available             (256) 722-9985
> Joel Sherrill, Ph.D.             Director of Research&  Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/b100b6a1/attachment-0001.html>
