Virtualbox RTEMS Setup
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jul 19 17:12:22 UTC 2012
On 07/19/2012 12:05 PM, Aric Hunter wrote:
> Fantastic!!!
> I looked into /home/rtems/qemu/install/bin and saw the
> qemu-system-i386 file that you mentioned, and after the update
> everything with the i386/pc386 works just fine.
> If you have time:
> How do I get qemu-system-arm?
> Is it as simple as another git update?
On that virtualbox image, the qemu was pulled from their git
and built. You just need to do their build and let it build everything.
I restricted it to i386 for size.
> Thanks oodles,
> Aric Hunter
> On Thu, Jul 19, 2012 at 9:27 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 07/19/2012 11:25 AM, Aric Hunter wrote:
>> I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
>> I haven't tried solution 2.
>> So, for solution 2, somewhere in the pc386 script it attempts to
>> run qemu but it should be qemu-system-i386?
> Yep.
> You could update the rtems-testing git module and type make :)
> ls /home/rtems/qemu/install/bin and see what's there
>> I will look for that.
>> Thanks for the amazingly quick replies,
>> Aric Hunter
>> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill
>> Hi
>> I know this has been answered before but I don't recall which
>> answer it is:
>> (1) qemu is not in your PATH. The qemu installation was
>> left out of setting the PATH in the setenv script
>> (2) It is really called qemu-system-i386 and the script
>> needs to use the correct name. qemu renamed this.
>> -joel
>> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>> Hello,
>> I am attempting to get the RTEMS development station
>> setup on the Centos virtualbox.
>> I was following the instructions on the wiki:
>> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>> I got to the section for testing the i386/pc386 without
>> any problems, but then I tried to do tho the following
>> command:
>> pc386 -i
>> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
>> and got this error:
>> /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line
>> 298: type: qemu: not found
>> FAILED: Path appears to be broken (cannot find qemu)
>> Any ideas as to what I am missing/doing incorrectly?
>> My ultimate goal is to run lm3s6965 instead of pc386, but
>> I get the same error with either.
>> Thanks,
>> Aric Hunter
>> Joel Sherrill, Ph.D. Director of Research&
>> Development
>> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>
>> On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Support Available(256) 722-9985 <tel:%28256%29%20722-9985>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/7b76ec80/attachment-0001.html>
