Clarification on Rate montonic
    domenico.dileo at unina.it
    Mon Jun  4 21:29:43 UTC 2012
Hello,
With the code hereafter, I run two periodic tasks (PER0 and PER1)
and scheduled them with the rate monotonic.
Also, a log of the excution follows the code.
PER0 has period 6000 ticks, while PER1 215.
Questions:
a) Since PER0 's pariod >> PER1's period should be PER1
the first to be scheduled?
According to the log, PER0 is the first one
b) how should I modify the code in order to have
PER1 scheduled before PER0?
Of course if I swap periodic_task(task_id[0], 6000);
with periodic_task(task_id[0], 215) I can observer
PER1 scheuled before PER0.
It seems that the first task to be scheduled
is the first to execute (with the call to the function
rtems_rata_monotonic_period).
Thank you in advance,
init.c code
  int i = 0;
  int l = 1;
  for(i; i< 3; i++){
	task_names[ i ] = rtems_build_name( 'P', 'R', '0'+i , ' ' );
	status = rtems_rate_monotonic_create(task_names[i], &task_id[i]);
	if(status == RTEMS_SUCCESSFUL){
	printf("Task %s created with id %d \n",
rtems_object_get_name(task_id[i],sizeof(task_names[i]),task_name),
task_id[i]);
		}else{
		printf("Failed to create task %s  with status %i \n",
rtems_object_get_name(task_id[i],NAME_LENGTH,task_name), status);
//rtems_rate_monotonic_reset_all_statistics();
//for(i = 0; i < 3; i++)
periodic_task(task_id[1], 215);
//wake up init after 5 seconds
  status = rtems_task_wake_after(ticks_per_second*10);
   // delete init task after starting the three working tasks
    rtems_rate_monotonic_report_statistics();
int j = 0;
for(j; j<=3;j++){
	rtems_rate_monotonic_delete(task_id[j]);
  status = rtems_task_delete( RTEMS_SELF );
   rtems_shutdown_executive(result);
tasks.c
rtems_task periodic_task(
   rtems_id task_id,
   rtems_interval period
   rtems_time_of_day time;
   rtems_status_code status;
   rtems_interval interval;
   uint32_t          ticks_since_boot;
   uint32_t          count;
   char task_name[NAME_LENGTH];
   count = 0;
   //task_id = rtems_task_self();
   while( count < 10 ) {
     count++;
     status = rtems_clock_get_tod( &time );
     if(status != RTEMS_SUCCESSFUL){
	printf("\n FAILED TO GET TIME OF THE DAY \n");
   printf("\n\n %s - is running \n",
rtems_object_get_name(task_id,NAME_LENGTH,task_name));
   print_time( " - current time - ", &time, "\n" );
   ticks_since_boot = rtems_clock_get_ticks_since_boot();
   printf(" - Ticks since boot: %" PRIu32 "\n", ticks_since_boot);
   status = rtems_rate_monotonic_period(task_id,period);
  	if(status == RTEMS_TIMEOUT){
		rtems_rate_monotonic_delete(task_id);
LOG
Task PR0 created with id 1107361793
Task PR1 created with id 1107361794
Task PR2 created with id 1107361795
  PR0  - is running
  - current time - 00:00:00   05/05/2012
  - Ticks since boot: 0
  PR0  - is running
  PR0  - is running
  - current time - 00:00:03   05/05/2012
  - Ticks since boot: 6076
  PR0  - is running
  - current time - 00:00:06   05/05/2012
  - Ticks since boot: 12055
  PR0  - is running
  - current time - 00:00:09   05/05/2012
  - Ticks since boot: 18087
  PR0  - is running
  - current time - 00:00:12   05/05/2012
  - Ticks since boot: 24068
  PR0  - is running
  - current time - 00:00:15   05/05/2012
  - Ticks since boot: 30099
  PR0  - is running
  - current time - 00:00:18   05/05/2012
  - Ticks since boot: 36098
  PR0  - is running
  - current time - 00:00:21   05/05/2012
  - Ticks since boot: 42071
  PR0  - is running
  - current time - 00:00:24   05/05/2012
  - Ticks since boot: 48072
  PR1  - is running
  - current time - 00:00:27   05/05/2012
  - Ticks since boot: 54096
  PR1  - is running
  - Ticks since boot: 54200
  PR1  - is running
  - Ticks since boot: 54423
  PR1  - is running
  - Ticks since boot: 54655
  PR1  - is running
  - Ticks since boot: 54840
  PR1  - is running
  - Ticks since boot: 55104
  PR1  - is running
  - Ticks since boot: 55271
  PR1  - is running
  - Ticks since boot: 55526
  PR1  - is running
  - Ticks since boot: 55712
  PR1  - is running
  - Ticks since boot: 55937
Period information by period
--- CPU times are in seconds ---
--- Wall times are in seconds ---
    ID     OWNER COUNT MISSED          CPU TIME                  WALL TIME
                                     MIN/MAX/AVG                MIN/MAX/AVG
0x42010001 UI1      9      0 0.000000/0.065991/0.047860
0.000000/0.066002/0.047885
0x42010002 UI1      9      0 0.044008/0.078422/0.058316
0.044010/0.078501/0.058371
0x42010003 UI1      0      0
