BUG? stack corruption in posix thread.
Tue Jun 12 20:47:37 UTC 2012
I agree with your analysis. Dispatching should be disabled
once all resources are allocated and before _Thread_Start
is called.
But is it the capture thread or stack overflow checker
that is writing the pattern?
I assume you have a patch for this and it is helping?
On 06/12/2012 03:39 PM, Till Straumann wrote:
> I observe pretty reproducable crashes when using pthreads under rtems-4.9.
> It seems that a function running in a new pthread context finds '0xdeaddead'
> on the stack upon returning to its caller and jumps into the wild.
> Apparently, the capture engine overwrites the task's stack with 0xdeaddead
> *after* the task is already running.
> I believe that 'pthread_create()' is the culprit. It creates a SCORE thread
> and then calls
> _Thread_Start( )
> *without* disabling thread-dispatching.
> However, _Thread_Start() marks the thread as 'runnable' *before* calling
> user extensions (_Thread_Start() body):
>     if ( _States_Is_dormant( the_thread->current_state ) )
> {../../score/src/apimutexunlock.c
>       the_thread->Start.entry_point      = (Thread_Entry) entry_point;
>       the_thread->Start.prototype        = the_prototype;
>       the_thread->Start.pointer_argument = pointer_argument;
>       the_thread->Start.numeric_argument = numeric_argument;
>       _Thread_Load_environment( the_thread );
>       _Thread_Ready( the_thread );
>       _User_extensions_Thread_start( the_thread );
>       return true;
>     return false;
> Therefore, could it not be that the thread is already scheduled *before*
> user extensions are executed? In this scenario, the following race condition
> could occur:
> 1. thread X calls pthread_create
> 2. _Thread_Start() marks new thread Y 'ready'
> 3. 'Y' is scheduled, calls stuff and blocks
> 4. 'X' runs again and executes user extensions for 'Y'
> 5. capture engine's 'thread_start' extension fills 'Y's stack with
> 0xdeaddead
> 6. 'Y' is scheduled again, when popping a return address from the stack
>      it jumps to 0xdeaddead and crashes the system.
> NOTES:
>    - other APIs (rtems, itron) *have* thread-dispatching disabled around
> _Thread_Start()
>    - the current 'master' branch seems to still suffer from this
>    - I consider this a serious bug.
> -- Till
Joel Sherrill, Ph.D.             Director of Research&   Development
