Patche: *** strip count l is not a number?
vai bas vai.csse at gmail.com
Fri Mar 16 11:05:42 UTC 2012
Dear respected RTEMS user,
              I found <Patche: *** strip count l is not a number> when I
was building RTEMS for Ubuntu. The RTEMS source code version is 4.11. I
found it when I was doing
../../archive/binutils-2.21-rtems4.11-20110107.diff | pathc -pl --dry-run .
Can someone tell me that why we should do it. After hitting enter key I got
comment that <Patch: *** stripe count l is not a number> Why this?
I am using the documentation from the url
www.rtems.org/wiki/index.php/building_the_RTEMS_toolset_of_Ubuntu to do it.
Thank you as advance.
Best regards
Suresh
URL: <http://lists.rtems.org/pipermail/users/attachments/20120316/dd3df6a7/attachment.html>
