RTEMS building
vai bas vai.csse at gmail.com
Thu Mar 22 21:36:36 UTC 2012
Hello,
         My RTEMS building process goes up to configure and build
successfully with following information in console :
rtems/tools/b-rtems-4.10-testing$ ../rtems-4.10.0/configure
--enable-rtems-debug\--target=pc386-rtems4.10 --enable-posix
--prefix=/opt/rtems-4.10\--enable-networking --enable-cxx
--enable-rtemsbsp="pc386" --enable-maintainer-mode
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.10.0
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/bash '../../../rtems-4.10.0/tools/build/configure'
'--prefix=/opt/rtems-4.10--enable-networking' '--host=i686-pc-linux-gnu'
'--build=i686-pc-linux-gnu'  '--enable-rtems-debug--target=pc386-rtems4.10'
'--enable-posix' '--enable-cxx' '--enable-rtemsbsp=pc386'
'--enable-maintainer-mode' '--target=i686-pc-linux-gnu'
 '--cache-file=/dev/null' '--srcdir=../../../rtems-4.10.0/tools/build'
checking for strtol... yes
checking for bash... /bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/bash '../../../rtems-4.10.0/tools/cpu/configure'
 '--cache-file=/dev/null' '--srcdir=../../../rtems-4.10.0/tools/cpu'
=== configuring in generic
(/home/vai/study/rtems/tools/b-rtems-4.10-testing/testsuites/tools/generic)
../../../../rtems-4.10.0/testsuites/tools/generic/configure
--disable-option-checking '--prefix=/opt/rtems-4.10--enable-networking'
 '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu'
'--enable-rtems-debug--target=pc386-rtems4.10' '--enable-posix'
'--enable-cxx' '--enable-rtemsbsp=pc386' '--enable-maintainer-mode'
'--target=i686-pc-linux-gnu' 'build_alias=i686-pc-linux-gnu'
'host_alias=i686-pc-linux-gnu' 'target_alias=i686-pc-linux-gnu'
--srcdir=../../../../rtems-4.10.0/testsuites/tools/generic
config.status: creating make/Makefile
rtems/tools/b-rtems-4.10-testing$ make all
Making all in make
make[1]: Entering directory
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/make'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory
Making all in tools/build
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/tools/build'
make  all-am
make[2]: Entering directory
make[2]: Leaving directory
Making all in tools/cpu
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/tools/cpu'
Making all in generic
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/c'
Making all in .
make[2]: Nothing to be done for `all-am'.
`/home/vai/study/rtems/tools/b-rtems-4.10-testing'
make[1]: Nothing to be done for `all-am'.
Everything seems okey in my opinion. Next step I tried to install using
following command line using from this url
http://www.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu as
resource
rtems/tools/b-rtems-4.10-testing$ sudo PATH=/opt/rtems-4.10/bin:${PATH}
make install
Making install in make
make[2]: Nothing to be done for `install-exec-am'.
test -z "/opt/rtems-4.10--enable-networking/make" || /bin/mkdir -p
 /usr/bin/install -c -m 644 ../../rtems-4.10.0/make/main.cfg
../../rtems-4.10.0/make/leaf.cfg '/opt/rtems-4.10--enable-networking/make'
test -z "/opt/rtems-4.10--enable-networking/make/Templates" || /bin/mkdir
-p "/opt/rtems-4.10--enable-networking/make/Templates"
 /usr/bin/install -c -m 644 ../../rtems-4.10.0/make/Templates/Makefile.dir
../../rtems-4.10.0/make/Templates/Makefile.leaf
../../rtems-4.10.0/make/Templates/Makefile.lib
'/opt/rtems-4.10--enable-networking/make/Templates'
test -z "/opt/rtems-4.10--enable-networking/make/custom" || /bin/mkdir -p
 /usr/bin/install -c -m 644 ../../rtems-4.10.0/make/custom/default.cfg
'/opt/rtems-4.10--enable-networking/make/custom'
Making install in tools/build
test -z "/opt/rtems-4.10--enable-networking/bin" || /bin/mkdir -p
  /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
'/opt/rtems-4.10--enable-networking/bin'
 /usr/bin/install -c install-if-change
make[2]: Nothing to be done for `install-data-am'.
Making install in tools/cpu
Making install in generic
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/tools/cpu/generic'
make[3]: Entering directory
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory
Making install in testsuites/tools
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/testsuites/tools'
`/home/vai/study/rtems/tools/b-rtems-4.10-testing/testsuites/tools/generic'
 /usr/bin/install -c difftest
'/opt/rtems-4.10--enable-networking/bin/./i686-pc-linux-gnu-difftest'
 /usr/bin/install -c sorttimes
'/opt/rtems-4.10--enable-networking/bin/./i686-pc-linux-gnu-sorttimes'
Making install in c
Making install in .
I found above information in my console. Can some experienced person make
me understood that what should I do to run this RTEMS in my system further?
Is there any problem in installation in given information? After that
information nothing happened.. How can I run this RTEMS in my Virtual Box
or how it should work??
            Thank you as advance.
Best regards
Vai,
Russia
URL: <http://lists.rtems.org/pipermail/users/attachments/20120323/aa898007/attachment.html>
