Hello World Example
    Dhruva T.B.
    dhruva92 at gmail.com
    Fri Mar 23 13:00:17 UTC 2012
Ok, these are the steps I took   ( I had sudo access throughout) -:
1) Downloaded and extracted the tarballs for binutils, gcc-core, gcc-g++,
gdb, newlib, mpc and mpfr.
2) Then for binutils created a seperate  folder and ran
../binutils-2.20/*configure
--target=sparc-rtems4.10* *--prefix=/opt/rtems4.10*.
    Then ran *make all *followed by make info and finally make install.
3) Then ran a similar configure script for gcc -:
     ->cd ../gcc-4.63/
     -> ln -s ../newlib-1.20.0/newlib
     -> cd ..; -> mkdir gcc-temp;
     -> cd gcc-temp
     -> ../gcc-4.63/*configure --target=sparc-rtems4.10 --with-gnu-as
--with-newlib --verbose --enable-threads --enable-languages="c,c++"
     -> make all; -> make info; -> make install
4)  At this point I ran the bootstrap inside my rtems-4.10.2 folder. I also
set my path with *export PATH=/opt/rtems4.10/bin:$PATH*
5) Then I cd into a directory called b-rtems and ran the configure code in
it with ../rtems-4.10.2/*configure --target=sparc-rtems4.10
--enable-rtemsbsp=sis --enable-        tests=samples --disable-posix
--disable-itran --prefix=/opt/rtems4.10*
I then ran make all and got the following as the last couple of lines of
output -:
make[5]: *** [kern/libnetworking_a-uipc_
socket.o] Error 1
make[5]: Leaving directory
`/home/dhruva/RTEMS/Tools/b-rtems/sparc-rtems4.10/c/sis/cpukit/libnetworking'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory
`/home/dhruva/RTEMS/Tools/b-rtems/sparc-rtems4.10/c/sis/cpukit'
make[3]: *** [all] Error 2
make[3]: Leaving directory
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/dhruva/RTEMS/Tools/b-rtems/sparc-rtems4.10/c/sis'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/dhruva/RTEMS/Tools/b-rtems/sparc-rtems4.10/c'
make: *** [all-recursive] Error 1
6) Not sure what the error is here but I ran make install anyway.
I then checked the sparc-rtems4.10/c/sis/testsuites/samples/ticker
directory and only found a Makefile there.
Not sure where I am going wrong.
I then went back to the original rtems4.10 directory and found my way to
the testsuites ticker folder. I tried sparc-rtems4.10-gcc init.c to see
what would happen and got an error about missing header file 'rtems.h'. Not
sure where its supposed to be but hoping that might help.
Hoping to find a fix that doesn't begin with -' Start over, except...'  :).
Dhruva T.B.,
3rd Year Electronics And Instrumentation Engineer,
Birla Institute Of Technology And Science (BITS)-Pilani, Goa,
India
Contact : +91-9503817694
URL: <http://lists.rtems.org/pipermail/users/attachments/20120323/51a6946e/attachment.html>
