Detecting when running in an ISR ?
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Mar 28 16:52:34 UTC 2012
On 03/28/2012 10:48 AM, Cudmore, Alan P. (GSFC-5820) wrote:
> On our RTEMS 4.10 project ( m68k/coldfire ), I have an exception handler that does a number of things such as closing files before restarting our processor card.
> This works fine when a task has an exception, but did not work too well when I caught an exception in an ISR.
> I found this macro:
> _ISR_Is_in_progress
> Which I can use to detect if the exception handler is running in an ISR. Is that a good enough way to detect that the code is running in the context of an ISR? Or is there a better/more standard way?
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/c_user/c_user00106.html
bool rtems_interrupt_is_in_progress( void );
> Another option would be to have a high priority exception task running, just waiting to handle the exception clean up activity. The exception handler could use a semaphore to kick off the task.
> Thanks,
> Alan
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120328/2b3420c1/attachment.html>
