Detecting when running in an ISR ?
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Wed Mar 28 16:57:37 UTC 2012
On Mar 28, 2012, at 12:52 PM, Joel Sherrill wrote:
On 03/28/2012 10:48 AM, Cudmore, Alan P. (GSFC-5820) wrote:
On our RTEMS 4.10 project ( m68k/coldfire ), I have an exception handler that does a number of things such as closing files before restarting our processor card.
This works fine when a task has an exception, but did not work too well when I caught an exception in an ISR.
I found this macro:
_ISR_Is_in_progress
Which I can use to detect if the exception handler is running in an ISR. Is that a good enough way to detect that the code is running in the context of an ISR? Or is there a better/more standard way?
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/c_user/c_user00106.html
bool rtems_interrupt_is_in_progress( void );
Just what I was looking for , thanks!
I guess I should stop using "grep" as my manual :)
Alan
Another option would be to have a high priority exception task running, just waiting to handle the exception clean up activity. The exception handler could use a semaphore to kick off the task.
Thanks,
Alan
rtems-users mailing list
rtems-users at rtems.org<mailto:rtems-users at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research& Development
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20120328/28598296/attachment.html>
