Starting with RTEMS
Binkowski, Cassio
cassioiks at gmail.com
Sun Mar 4 16:38:00 UTC 2012
On Sun, Mar 4, 2012 at 12:36 PM, Ralf Corsepius <ralf.corsepius at rtems.org>wrote:
> On 03/04/2012 04:14 PM, Binkowski, Cassio wrote:
>> On Sun, Mar 4, 2012 at 3:44 AM, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 4/03/12 9:26 AM, Binkowski, Cassio wrote:
>> I have done the process all over again but still accusing that
>> there is
>> no g++ and c++.
>> What is reporting it cannot find g++ and c++ ?
>> Ok, the exact lines are the following:
>> checking for avr-rtems4.10-g++... no
>> configure: error: no acceptable c++ found in $PATH
>> configure: error:
>> ../../../../../../rtems-4.10.**2/c/src/../../testsuites/**samples/
>> configure failed for samples
>> configure: error: /bin/sh
>> '../../../../../rtems-4.10.2/**c/src/../../testsuites/co
>> nfigure' failed for ../../testsuites
>> make[2]: *** [avrtest] Error 1
>> make[2]: Leaving directory
>> `/c/opt/rtems-4.10/rtems4.10-**build/avr-rtems4.10/c'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> make: *** [all-recursive] Error 1
>> These the last lines of a large dump generated by the command "make all".
> How does your call to configure look like?
Just like this:
../rtems-4.10.2/configure --target=avr-rtems4.10 --enable-rtemsbsp=avrtest
--enable-cxx --enable-tests=samples
How can I download a pre-built development environment? The only virtual
machine I could find was a CentOS machine. Which was discontinued by the
way.
> Ralf
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120304/35073c98/attachment-0001.html>
