Starting with RTEMS
Gedare Bloom
gedare at rtems.org
Sun Mar 4 16:52:08 UTC 2012
On Sun, Mar 4, 2012 at 11:38 AM, Binkowski, Cassio <cassioiks at gmail.com> wrote:
> On Sun, Mar 4, 2012 at 12:36 PM, Ralf Corsepius <ralf.corsepius at rtems.org>
> wrote:
>> On 03/04/2012 04:14 PM, Binkowski, Cassio wrote:
>>> On Sun, Mar 4, 2012 at 3:44 AM, Chris Johns <chrisj at rtems.org
>>> <mailto:chrisj at rtems.org>> wrote:
>>> On 4/03/12 9:26 AM, Binkowski, Cassio wrote:
>>> I have done the process all over again but still accusing that
>>> there is
>>> no g++ and c++.
>>> What is reporting it cannot find g++ and c++ ?
>>> Ok, the exact lines are the following:
>>> checking for avr-rtems4.10-g++... no
>>> configure: error: no acceptable c++ found in $PATH
>>> configure: error:
>>> ../../../../../../rtems-4.10.2/c/src/../../testsuites/samples/
>>> configure failed for samples
>>> configure: error: /bin/sh
>>> '../../../../../rtems-4.10.2/c/src/../../testsuites/co
>>> nfigure' failed for ../../testsuites
>>> make[2]: *** [avrtest] Error 1
>>> make[2]: Leaving directory
>>> `/c/opt/rtems-4.10/rtems4.10-build/avr-rtems4.10/c'
>>> make[1]: *** [all-recursive] Error 1
>>> make[1]: Leaving directory
>>> make: *** [all-recursive] Error 1
>>> These the last lines of a large dump generated by the command "make all".
>> How does your call to configure look like?
> Just like this:
> ../rtems-4.10.2/configure --target=avr-rtems4.10 --enable-rtemsbsp=avrtest
> --enable-cxx --enable-tests=samples
Try it without --enable-cxx since Ralf said c++ is not supported for AVR.
> How can I download a pre-built development environment? The only virtual
> machine I could find was a CentOS machine. Which was discontinued by the
> way.
The CentOS VM is up-to-date and supported. Follow the directions at
http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
