RTEMS on x86 PC
Fered a_Fered at yahoo.com
Tue Mar 6 18:29:01 UTC 2012
"kernel" command is for legacy grub.
> Hi,
> I think you need to define the kernel option in grub before issuing boot:
> > kernel (hd0,0)/hello.exe
> > boot
> Regards,
> Cláudio
> On Tue, Mar 6, 2012 at 2:02 PM, Fered <a_Fered at yahoo.com> wrote:
> > Hi;
> > The documents you said are old. (They point to legacy GRUB)
> > Then I read some manuals and did following steps but could not boot
> > RTEMS. 1- Installing GRUB on a USB disk in Linux:
> >        a. sudo mkfs.msdos /dev/sdb
> >        b. sudo mount /dev/sdb /media/MULTIBOOT
> >        c. grub-install --force --no-floppy
> > --root-directory=/media/MULTIBOOT \ /dev/sdb
> > 2- Copy samples to the disk:
> >        I copied hello.exe
> > 3- Boot system using the USB disk
> >        After booting, in GRUB's commanline, I wrote this command:
> >        boot (hd0)/hello.exe
> > And the output of this command was:
> > no loaded kernel
> > (When I issue 'ls (hd0)/' I see the file)
> > I built RTEMS for i386 archtecture and PC386 board. I tested hello.exe
> > by
> > pc386 script, that is run qemu and it worked.
> > Are these steps are correct?
> > Thanks.
> >> Hi,
> >> Yes you can test RTEMS in your PC. You just have to build RTEMS for
> >> the i386 architecture and pc386 (or later) board support package. Once
> >> you have a RTEMS application built you can use GRUB to boot it. (if
> >> you have grub already installed on your PC you just have to change the
> >> "kernel=" parameter to point to an RTEMS application)
> >> For more information on how to build RTEMS and a sample application:
> >> http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> >> http://wiki.rtems.org/wiki/index.php/Quick_Start
> >> http://wiki.rtems.org/wiki/index.php/Example_Application_Compiling
> >> For more information about the boot:
> >> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/i386/pc386/HOWTO
> >> http://wiki.rtems.org/wiki/index.php/Pc386
> >> http://wiki.rtems.org/wiki/index.php/QEMU
> >> Cláudio
> >> On Wed, Feb 22, 2012 at 11:03 AM, harryxiyou <harryxiyou at gmail.com>
wrote:
> >> > On Wed, Feb 22, 2012 at 3:58 PM, Fered <a_fered at yahoo.com> wrote:
> >> >> Hi,
> >> > Hi there,
> >> >> I'm newbie and want to test RTEMS on my PC.(on real hardware)
> >> >> Is it possible?
> >> > I think it is ok for us to test on our PC. I am now searching the
> >> > way,
> >> > too. I recommend some useful links for you. If you find the way
> >> > tell me please.
> >> > [0] http://wiki.rtems.org
> >> > [1] http://www.rtems.org/
> >> > [2] http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> >> > [3] http://git.rtems.org/
> >> > Thanks
> >> > Harry Wei
> >> > _______________________________________________
> >> > rtems-users mailing list
> >> > rtems-users at rtems.org
> >> > http://www.rtems.org/mailman/listinfo/rtems-users
