Any arm-rtems users?
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Mar 7 06:01:11 UTC 2012
On 03/06/2012 07:23 PM, Kirspel, Kevin wrote:
> I am an arm-rtems user (NXP LPC3250 BSP). Our makefiles are structured so that changing the GCC compiler is simple. I assume changes are needed for linkcmds since they are currently elf based. I don't see why I couldn't easily switch. But I may not know all the issues. I am currently using an ARM Cortex-M3 (arm-none-eabi) on a non-rtems platform and have had no issues.
There are subtile and hard to catch differences between arm-elf and
arm-eabi.
One such detail I am aware about is the set of GCC internal #defines.
They are slightly different between arm-elf and arm-eabi and
occasionally require patching.
One such case had been in newlib, which had gotten away unnoticed for
some time (c.f. newlib-1.20.0/newlib/libc/sys/rtems/machine/_types.h in
recent rtems-4.11 newlib patches).
Another detail, Sebastian recently found, whose impact is not yet fully
understood is "sizeof(enum) == 2" on arm-eabi (Probably all other RTEMS
toolchains, comprising arm-elf/rtems use "sizeof(enum) == 1").
Ralf
