Any arm-rtems users?
Sebastian Huber
Wed Mar 7 08:16:26 UTC 2012
On 03/06/2012 07:23 PM, Kirspel, Kevin wrote:
> I am an arm-rtems user (NXP LPC3250 BSP). Our makefiles are structured so that changing the GCC compiler is simple. I assume changes are needed for linkcmds since they are currently elf based. I don't see why I couldn't easily switch. But I may not know all the issues. I am currently using an ARM Cortex-M3 (arm-none-eabi) on a non-rtems platform and have had no issues.
We have a wike page regarding the ARM tool chain:
http://wiki.rtems.org/wiki/index.php/ARM-EABI
I changed all ARM BSP linker command files to use a base file which can easily
adopted to a specific board:
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
Let me emphasize again, that the so called GCC ARM ELF configuration is dead
according to the GCC ARM maintainer Richard Earnshaw. The name ELF is a bit
misleading since the EABI configuration uses also the ELF format.
http://gcc.gnu.org/ml/gcc-patches/2011-12/msg00692.html
Test suite results:
http://gcc.gnu.org/ml/gcc-testresults/2011-10/msg03523.html
http://gcc.gnu.org/ml/gcc-testresults/2011-11/msg00407.html
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
