RTEMS on x86 PC
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Mar 7 09:05:34 UTC 2012
On 03/07/2012 07:28 AM, Fered wrote:
> I found these instructions to boot using grub:
> multiboot (hd0)/hello.exe
> boot
> but after that, I see "Warning : This will be the last message on console" and
> no more messages.
> Are those instructions correct?
I don't know. grub1 and esp. grub2 varies between Linux distros to an
extend, it's hard to provide any recommendation :(
> Please help me. I should boot RTEMS on a x86 PC and have no much time.
I have all rtems executables installed in a separate partition and am
using a cascade of grubs to boot into different OSes (Fedora, CentOS,
openSUSE and one partition for RTEMS).
To achieve this, I have a "master grub" on a master-bootpartition which
redirects to other grub installations in other OS's boot partitions.
One of these partitions contains the RTEMS pc386 executables.
It (partition hd0,12) carries a boot/grub/grub.cfg which includes a file
pointing to all rtems-testcases
(grub.cfg contains: configfile (hd0,12)/rtems-grub2.cfg)
This rtems-grub2.cfg contains a long list of menuentries per rtems
executable, similar to this:
menuentry "4.11: pc386/testsuites/samples/base_sp/base_sp.exe" {
set root=(hd0,12)
multiboot (hd0,12)/i386-rtems4.11/c/pc386/testsuites/base_sp/base_sp.exe
To build these executables I mount the partition corresponding to
(hd0,12) under Linux, build RTEMS and install into this directory.
Then I let a script generate rtems-grub2.cfg and reboot.
Unfortunately, I set up this long time ago (ca. 2 years ago) and don't
recall all details anymore.
Ralf
