Building project - Eclipse
Mon Mar 12 15:55:05 UTC 2012
On 03/12/2012 04:23 PM, Binkowski, Cassio wrote:
> On Mon, Mar 12, 2012 at 11:14 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 03/12/2012 03:04 PM, Binkowski, Cassio wrote:
>         I have been trying to build a test project in eclipse but have neen
>         unable to
>         do so.
>         The configuration I've been using are the following:
>         Base path: /opt/rtems-4.11
>         BSP pah: /home/rtems/test/sparc-rtems4.__11
>     This is not a BSP path, try /home/rtems/test/sparc-rtems4.__11/sis or
>     whatever BSP you want.
> Well, it is still returning that "make invokation, error status 2".
> Is there anything else I can do?
Did you build an install a BSP?  Which name has it?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
