Building project - Eclipse
    Binkowski, Cassio
    cassioiks at gmail.com
    Mon Mar 12 16:55:16 UTC 2012
On Mon, Mar 12, 2012 at 1:07 PM, Sebastian Huber <
> On 03/12/2012 04:57 PM, Binkowski, Cassio wrote:
>> On Mon, Mar 12, 2012 at 12:55 PM, Sebastian Huber
>> <sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>
>> wrote:
>>    On 03/12/2012 04:23 PM, Binkowski, Cassio wrote:
>>        On Mon, Mar 12, 2012 at 11:14 AM, Sebastian Huber
>>        <sebastian.huber at embedded-__**brains.de<sebastian.huber at embedded-__brains.de>
>>        <mailto:sebastian.huber at __embe**dded-brains.de<http://embedded-brains.de>
>>        <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>>
>> wrote:
>>            On 03/12/2012 03:04 PM, Binkowski, Cassio wrote:
>>                I have been trying to build a test project in eclipse but
>> have neen
>>                unable to
>>                do so.
>>                The configuration I've been using are the following:
>>                Base path: /opt/rtems-4.11
>>                BSP pah: /home/rtems/test/sparc-rtems4.**____11
>>            This is not a BSP path, try /home/rtems/test/sparc-rtems4.**____11/sis
>> or
>>            whatever BSP you want.
>>        Well, it is still returning that "make invokation, error status 2".
>>        Is there anything else I can do?
>>    Did you build an install a BSP?  Which name has it?
>> Yes. I believe I did. I have built the SIS BSP for Sparc.
>> However, I'm not sure how the installation process works.
>> Can you help me out?
> Did you a "make install"?
Just to be sure. I have built it all over again and installed it.
Used "gmake all" and then "gmake install".
Still accusing those 2 errors on Eclipse.
Any thoughts?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120312/6e3208f1/attachment-0001.html>
