Building project - Eclipse
Sebastian Huber
Mon Mar 12 16:07:33 UTC 2012
On 03/12/2012 04:57 PM, Binkowski, Cassio wrote:
> On Mon, Mar 12, 2012 at 12:55 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 03/12/2012 04:23 PM, Binkowski, Cassio wrote:
> On Mon, Mar 12, 2012 at 11:14 AM, Sebastian Huber
> <sebastian.huber at embedded-__brains.de
> <mailto:sebastian.huber at __embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> On 03/12/2012 03:04 PM, Binkowski, Cassio wrote:
> I have been trying to build a test project in eclipse but have neen
> unable to
> do so.
> The configuration I've been using are the following:
> Base path: /opt/rtems-4.11
> BSP pah: /home/rtems/test/sparc-rtems4.____11
> This is not a BSP path, try /home/rtems/test/sparc-rtems4.____11/sis or
> whatever BSP you want.
> Well, it is still returning that "make invokation, error status 2".
> Is there anything else I can do?
> Did you build an install a BSP? Which name has it?
> Yes. I believe I did. I have built the SIS BSP for Sparc.
> However, I'm not sure how the installation process works.
> Can you help me out?
Did you a "make install"?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
