ARINC-653 API
张文杰 157724595 at 163.com
Fri Mar 16 14:14:01 UTC 2012
Hi, all:
    I am the student who implement the GSOC2011 project hypervisor for RTEMS.
In my original proposal i wanted port the linux to the RTEMS paravirtualization hypervisor
named AIR. But as the progress of project, the plan had changed into adapt the
lastest RTEMS to the AIR hypervisor. So what i did is make the lastest RTEMS run
under AIR successfully which contains a paravirtualization RTEMS kernel named
POK. If you want to know any information please free to contact me
At 2012-03-16 06:47:16,"Julien Delange" <julien.delange at gmail.com> wrote:
>On Thu, Mar 15, 2012 at 6:44 PM, WL <jolkaczad at gmail.com> wrote:
>> This is all valuable stuff, and the topic is getting more interesting
>> by the minute. I see that this would somewhat pick up where a last
>> year's GSoC project left off. Is the student still active in the
>> community? If not ,did he leave his work in a useable state? I'd like
>> to contact him since there's no need to do the same research again and
>> come to conclusions which have already been arrived at.
>Hello,
>Please have a look the the links below. Also, the whole project has
>several goals :
>1. Implement ARINC653 services in RTEMS. If you consider RTEMS only,
>you can only design intra-partition services (tasks, intra-partition
>comm. , etc ...). This is described in [3].
>2. Implement a prototype of a hypervisor to execute several RTEMS
>instance in different partitions (see proposal [4]). In that case, the
>work consists in (1) design a first prototype to execute RTEMS in
>several partition and (2) adapt RTEMS to call the hypervisor services
>for inter-partitions interactions. Once that is done, we can also
>implement ARINC653 inter-partitions services.
>So, implementing full ARINC653 compliance for RTEMS would require to
>do both tasks. The second project is more difficult but has more
>priority since this would be the fundation for building partitions
>using RTEMS. In addition, making the partitioned-bsp of RTEMS would be
>really tricky because it has to be as much generic as possible to fit
>with other separation kernel approaches (as AIR, XtratuM or POK).
>As far as I know, the GSOC 2011 project focuses on the second item of
>the work. It was based on AIR but unfortunately, it does not seem
>available (you can check on http://air.di.fc.ul.pt/). However, the
>report of this work is available as gdoc documents, you have to
>request access to it, links to ask are located on page [2]. Also, Joel
>may have more information about the status of the 2011 GSOC project
>related to this topic.
>Hope that helps,
>[1] http://wiki.rtems.org/wiki/index.php/RTEMSHyperVisor
>[2] http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode2011
>[3] http://wiki.rtems.org/wiki/index.php/ARINC653API
>[4] http://wiki.rtems.org/wiki/index.php/RTEMS_Paravirtualization
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120316/0f872227/attachment-0001.html>
