Error
Thu Mar 22 14:48:38 UTC 2012
On 03/22/2012 09:14 AM, vai bas wrote:
> Dear respected RTEMS users,
>          I'm trying to build RTEMS in Ubuntu 10.04 LTS. As a helpful
> document I am using this link :
> http://www.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu .
> Up to Run bootsrtap everything was okey. In next step in configure and
> build I got this comment :
>  user - rtems/tools$ ../rtems-4.10.0/configure --enable-rtems-debug \
> --target=i386-rtems4.10 --enable-posix --prefix=/opt/rtems-4.10 \
> --enable-networking --enable-cxx --enable-rtemsbsp="virtex"
> --enable-maintainer-mode
> bash: ../rtems-4.10.0/configure: No such file or directory
You have to be in a build directory which is at the same level as the
rtems source.
I also wonder if your cutting and pasting of the command and picking up
the line continuation "\" character could cause issues.
> rtems/tools$ cd rtems-4.10.0/
> rtems/tools/rtems-4.10.0$ ./configure --enable-rtems-debug \
> --enable-maintainer-modeconfigure: error: invalid variable name: `
> --target'
This is wrong on 3 counts that I see:
+ It is suffering from the \ eating a space and running the
arguments together in an incorrect way.
+ you are trying to compile a powerpc BSP (virtex) using the i386 target
architecture.
i386/pc386
powerpc/virtex
+ You are trying to configure in the RTEMS source tree
which is not supported.
>  I have source code 4.10.0 and I have build toolchane for Ubuntu using
> 4.10 source code!!! What I did wrong above? I have unarchive code in
> tools directory and done this operation.
>      Can someone tell me why it's like this? Thanks as advance
> Best regards
> Vai
Joel Sherrill, Ph.D.             Director of Research&   Development
