Project about Atomic Operations
yangwei weiyang
wei.a.yang at gmail.com
Mon Mar 26 13:40:14 UTC 2012
Hi Huber:
The atomic operations supported by c and c++ standard is built in
the compiler, like
GCC has some build-in atomic operations functions. you can see
http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Atomic-Builtins.html.
But Not all operations are supported by all target processors and
it is designed as a
standard library not for a operation system. So in my opinion we can
refer its implementation
but can use them directly.
Wenjie
Best Regards
2012/3/26 Sebastian Huber <sebastian.huber at embedded-brains.de>:
> Hi,
> atomic operations are now supported by the recent C and C++ standard. See
> http://en.wikipedia.org/wiki/C11_%28C_standard_revision%29
> http://www.hpl.hp.com/personal/Hans_Boehm/c++mm/
> Why don't we simply use them?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org
Wei Yang
Best Regards
