Error: can't find qemu
Gedare Bloom
gedare at rtems.org
Tue Mar 27 02:27:56 UTC 2012
This might help:
http://www.rtems.org/pipermail/rtems-users/2012-February/009534.html
I guess you have to figure out where qemu was installed and add it to
your PATH environment variable.
-Gedare
On Mon, Mar 26, 2012 at 9:44 PM, Xiaochen Pan <panx at seas.upenn.edu> wrote:
> Hi,
> I have built the pc386 bsp from the virtual box image which has i386 preinstalled using the following command:
> ./build_bsp i386 pc386
> But I can't run pc386 with qemu. The error messag is:
> FAILED: The path appears to be broken. (Cannot find qemu)
> How can I configure in order to boot it successfully?
> Regards,
> Xiaochen Pan
> rtems-users mailing list
> rtems-users at rtems.org
