Problems in booting MVME2304
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Mar 28 16:46:42 UTC 2012
On 03/28/2012 09:12 AM, Ziaulhaque Qazi wrote:
> Hi All
> First of all thanks to Thomas and Joe. With your help I was able to go
> one step forward. However still I could not succeed in booting. I am
> pasting below what was the response this time.
> After this the console was hung. Again I need your kind advice.
See below for comments.
Hopefully someone with a MVME230x can provide more help
but I think I can guide you in the direction of where things
are going astray.
> Thanks and Regards
> Zia
> _______________________________________________________________________________________________________________________________________________
> PPC1-Bug>nbo
> Network Booting from: DEC21140, Controller 0, Device 0
> Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
> Loading: hello.ralf
> Client IP Address = 10.1.22.45
> Server IP Address = 10.1.22.49
> Gateway IP Address = 10.1.22.1
> Subnet IP Address Mask = 255.255.255.0
> Boot File Name = hello.ralf
> Argument File Name =
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&183040, Bytes Loaded =&183040
> Bytes/Second =&91520, Elapsed Time =2 Second(s)
> Residual-Data Located at: $07F88000
> Model: 000000000000000000000000000(e2)
> Serial: MOT07C27F7
> Processor/Bus frequencies (Hz): 333364800/66672376
> Time Base Divisor: 4000
> Memory Size: 8000000
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> done
> Now booting...
> Unknown motorola board Please update
> libbsp/powerpc/shared/motorola/motorola.c
> cpu_type = E0
> base_mod = F9
These last three lines indicate the first level of the problem
and the file to fix. Apparently this file does not recognize the
cpu_type and base_mode versions.
Looking in the file, I see this entry in the table of known boards
which based on the code which matches I think should produce
a match
{0x1E0, 0xF9, PPC_604, "MVME 2300", mvme23xx_intmap,
prep_pci_swizzle},
You may want to sprinkle getMotorolaBoard() with some diagnostics
and see why it isn't matching. If it matched, then it should be OK.
> Welcome to rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2304) on
> idreg 0 = 0x48011057
> OpenPIC found at C1000000.
> pci : Interrupt routing not available for this bsp
> Cleared PCI errors: pci_stat was 0x2280
Since it doesn't manage to match the known list of boards,
it doesn't know what to do.
At this point, it locks up.
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120328/bf4349d6/attachment-0001.html>
