Coldfire (MCF5235) Interrupt Problem
Ivica Eftimovski
IEFTIMOVSKI at teledyne.com
Fri May 11 15:55:56 UTC 2012
Hi all,
I am just starting with RTEMS and I am trying to interface the MCF5235 BCC board to our existing hardware. I am trying to set it to use *IRQ4, which should have fixed level/priority.
When I execute the code noted below, the interrupts are disabled properly, the vector seems set and interrupts are re-enabled. But anytime I ground*IRQ4 (default high) line while my example program is running, I do not vector to the ISR.
I fashioned my code using the clock/network/console code as guide, and those work great.
Can anyone please give me a hint of what am I doing wrong?
------------------------------------- CODE -------------------------------------
#define TPU_INT_VECTOR (64+4)
#define TPU_IRQ_LEVEL 4
#define TPU_IRQ_PRIORITY 4
void InitTPUInterrupt(void);
static rtems_isr TPUInterruptHandler(rtems_vector_number vector);
#define TPUInterruptSetPriority() \
do { \
MCF5235_INTC0_ICR4 = \
MCF5235_INTC_ICR_IL(TPU_IRQ_LEVEL) | \
MCF5235_INTC_ICR_IP(TPU_IRQ_PRIORITY); \
} while(0)
#define TPUInterruptSetHandler(_level,_vector,_old_handler) \
do { \
rtems_interrupt_disable(_level); \
MCF5235_INTC0_IMRL &= ~(MCF5235_INTC0_IMRL_INT4 | \
MCF5235_INTC0_IMRL_MASKALL); \
handle_status = rtems_interrupt_catch(TPUInterruptHandler, \
TPU_INT_VECTOR, &old_handler); \
rtems_interrupt_enable(level); \
} while(0)
void InitTPUInterrupt(void) {
rtems_interrupt_level level;
rtems_isr_entry old_handler;
uint16 status;
TPUInterruptSetPriority();
TPUInterruptSetHandler(level, TPU_INT_VECTOR, old_handler);
asm ("move.w %%sr ,%0;" : "=r"(status));
static rtems_isr
uint volatile chan = vector - TPU_INT_VECTOR;
printf("\nGot interrupt number: %i", chan);
rtems_interrupt_clear(MCF5235_INTC0_ICR4);
rtems_task Init(
rtems_task_argument ignored
InitTPUInterrupt();
URL: <http://lists.rtems.org/pipermail/users/attachments/20120511/26365e3f/attachment.html>
