MCF5485EVB Board Console problems
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Tue May 1 16:05:17 UTC 2012
Chris,
we have a Freescale Evaluation board in our company and will
cross-check your results in the next days (today is holiday in
germany). Maybe we can help you a bit there.
wkr,
Thomas.
Am 01.05.2012 17:56, schrieb Chris Xenophontos:
> Thomas, I have the sample applications, but nothing seems to run.
> I can only get our application to run if I do not enable
> CONSOLE_DRIVER and use printk. All startup code, etc built from
> RTEMS BSP, etc runs as expected.
> I believe we have the real mcf5484FireEngine board, according to
> docs that were delivered with the board: dBUG> reset ColdFire
> MCF548X on the M5485EVB Firmware v4a.1a.1d (Built on Dec 6 2004
> 11:50:38) Copyright 1995-2004 Freescale Semiconductor, Inc. Enter
> 'help' for help. dBUG> thanks Chris
> On Tue, May 1, 2012 at 11:37 AM, Thomas Doerfler
> <Thomas.Doerfler at embedded-brains.de> wrote:
>> Chris,
>> can you successfully execute one of the "sample" applications
>> built for this board, like "ticker.exe" ? These applications
>> should be present in your "install" tree since you haven't
>> disabled them explicitly in your configure line.
>> Are you working with a real "mcf5484FireEngine" board or is it
>> different in some areas?
>> Which boot monitor do you use?
>> wkr, Thomas.
>> Am 01.05.2012 17:19, schrieb Chris Xenophontos:
>>> The problem occurs regardless if CONFIGURE_TERMIOS_DISABLED is
>>> #defined or not. We've repeatedly tried it both ways.
>>> On Tue, May 1, 2012 at 10:48 AM, Chris Xenophontos
>>>> is #defined or not. We've repeatedly tried it both ways.
>>>> On Tue, May 1, 2012 at 10:43 AM, Joel Sherrill
>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>> You can't disable TERMIOS and have a working console
>>>>> driver.
>>>>> On 05/01/2012 09:41 AM, Chris Xenophontos wrote:
>>>>>> Hello, In continuing to port a previous application to an
>>>>>> MCF5485EVB board with RTEMS 4.10.2, We're having problems
>>>>>> initializing the console. Currently, we successfully
>>>>>> configured as follows:
>>>>>> ./rtems-4.10.2/configure --target=m68k-rtems4.10
>>>>>> --enable-rtemsbsp=m5484FireEngine
>>>>>> --prefix=/opt/rtems-4.10
>>>>>> gmake RTEMS_BSP="m5484FireEngine" install
>>>>>> The problem is that when
>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is #defined,
>>>>>> Either the application is not initializing, or no output
>>>>>> is sent through serial port. Only way to get any
>>>>>> messages to console window is to use printk.
>>>>>> The snipped below had previously worked as shown, on
>>>>>> MCF5235 board with RTEMS 4.9 - no issues with console.
>>>>>> Is additional configuration required for m5484FireEngine
>>>>>> BSP?
>>>>>> thanks Chris Xenophontos
>>>>>> include<stdio.h> #include<stdlib.h> #include<rtems.h>
>>>>>> #include<bsp.h> #include<unistd.h>
>>>>>> #include<rtems/rtems_bsdnet.h> #include
>>>>>> "networkconfig.h" #include "tids.h" #include "pids.h"
>>>>>> #include "ostasks.h" #include "debug.h"
>>>>>> rtems_task Init( rtems_task_argument ignored ); extern
>>>>>> int myAppMain( void );
>>>>>> rtems_task Init( rtems_task_argument ignored ) { // !!
>>>>>> forced to use prink - #defining
>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER won't
>>>>>> initialize - see below
>>>>>> printk( "\n\n\nMMS Trainer Initializing...\n" ); printk(
>>>>>> "\n*** RTEMS Info ***" ); printk( "\n" ); printk(
>>>>>> "\nsizeof( Objects_Control *): 0x%08X", (
>>>>>> unsigned int )sizeof( Objects_Control *)); printk(
>>>>>> "\nsizeof( rtems_name *): 0x%08X", (
>>>>>> unsigned int )sizeof( rtems_name *)); printk( "\nsizeof(
>>>>>> rtems_name ): 0x%08X", ( unsigned int
>>>>>> )sizeof( rtems_name )); printk( "\n" ); printk(
>>>>>> "\nsizeof(Thread_Control): 0x%08X", (
>>>>>> unsigned int )sizeof(Thread_Control )); printk(
>>>>>> "\nCONTEXT_FP_SIZE: 0x%08X", (
>>>>>> unsigned int )CONTEXT_FP_SIZE ); printk(
>>>>>> "\nSTACK_MINIMUM_SIZE: 0x%08X",
>>>>>> STACK_MINIMUM_SIZE ); printk( "\nsizeof(
>>>>>> RTEMS_API_Control ): 0x%08X", ( unsigned int
>>>>>> )sizeof( RTEMS_API_Control )); printk( "\n" );
>>>>>> rtems_bsdnet_initialize_network();
>>>>>> rtems_bsdnet_show_inet_routes ();
>>>>>> rtems_bsdnet_show_mbuf_stats ();
>>>>>> rtems_bsdnet_show_if_stats (); rtems_bsdnet_show_ip_stats
>>>>>> (); rtems_bsdnet_show_icmp_stats ();
>>>>>> rtems_bsdnet_show_udp_stats ();
>>>>>> rtems_bsdnet_show_tcp_stats ();
>>>>>> #ifdef STACK_DEBUG Stack_check_Initialize(); #endif
>>>>>> printk( "\nEntering xmain....\n" );
>>>>>> myAppMain(); /* application, startup, etc */
>>>>>> exit ( 0 ); };
>>>>>> #define TASK_INTLEVEL 0 #define CONFIGURE_INIT #define
>>>>>> CONFIGURE_INIT_TASK_ATTRIBUTES ( RTEMS_FLOATING_POINT |
>>>>>> RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_ASR |
>>>>>> RTEMS_INTERRUPT_LEVEL(TASK_INTLEVEL))
>>>>>> #define CONFIGURE_MAXIMUM_TASKS 20 #define
>>>>>> CONFIGURE_MAXIMUM_TIMERS 3
>>>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES 20 #define
>>>>>> CONFIGURE_MAXIMUM_MESSAGE_QUEUES 24
>>>>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024) #define
>>>>>> CONFIGURE_INIT_TASK_PRIORITY 120 #define
>>>>>> CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>>>>>> RTEMS_NO_TIMESLICE | \ RTEMS_NO_ASR | \
>>>>>> RTEMS_INTERRUPT_LEVEL(0))
>>>>>> //#define CONFIGURE_MAXIMUM_DEVICES 4 #define
>>>>>> CONFIGURE_MAXIMUM_DRIVERS 3
>>>>>> #define ADA_TASKS 0
>>>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE //#define
>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER !!!! no
>>>>>> initialization/console output when defined !!! #define
>>>>>> CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>>> // #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM #define
>>>>>> CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4 /* 30 */
>>>>>> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>>>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>>>> #ifdef STACK_DEBUG #define STACK_CHECKER_ON #endif
>>>>>> #include<rtems/confdefs.h>
>>>>>> #define NETWORK_TASK_PRIORITY 80
>>>>>> _______________________________________________
>>>>>> rtems-users mailing list rtems-users at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>> -- Joel Sherrill, Ph.D. Director of Research&
>>>>> Development joel.sherrill at OARcorp.com On-Line
>>>>> Applications Research Ask me about RTEMS: a free RTOS
>>>>> Huntsville AL 35805 Support Available (256)
>>>>> 722-9985
>>> _______________________________________________ rtems-users
>> -- -------------------------------------------- Embedded Brains
>> GmbH Thomas Doerfler Obere Lagerstr. 30 D-82178
>> Puchheim Germany email:
>> Thomas.Doerfler at embedded-brains.de Phone: +49-89-18908079-2 Fax:
>> +49-89-18908079-9
> _______________________________________________ rtems-users mailing
Embedded Brains GmbH
D-82178 Puchheim Germany
email: Thomas.Doerfler at embedded-brains.de
Fax: +49-89-18908079-9
