Supported ARM BSPs
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 3 12:48:06 UTC 2012
On 05/03/2012 03:36 AM, Fered wrote:
> Hi;
> I repaete my question again:
> > Are all available BSPs in the following address?
> > http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm
> And some other questions:
> I this page, we have lm3s69xx
> <http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx> and
> stm32f4
> <http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/stm32f4><http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/stm32f4>
> but I don't see a folder for LPC17xx. Which folder points to LPC17xx?
[joel at iceland libbsp]$ pwd
/home/joel/rtems-4.11-work/rtems-testing/rtems/rtems/c/src/lib/libbsp
[joel at iceland libbsp]$ find . -name "lpc1*.cfg"
./arm/lpc24xx/make/custom/lpc17xx_ea_ram.cfg
./arm/lpc24xx/make/custom/lpc17xx_ea_rom_int.cfg
> Is BSP for lm3s69xx works only on Qemu?
This is one for Sebastian.
> Thanks a lot for your answers.
> > Thank you.
> > Sebastian Huber wrote:
> > > On 30/04/12 05:50, Fered wrote:
> > > > The problem is which BSPs are actually available?!
> > > If you want to add a new BSP, please use the Git master:
> > > The list on the wiki refers to the BSPs available on the Git master.
> > > > I want to buy a board and I'm not sure which board has a BSP
> > > > (whithout
> > > > modification or any additional attempt!).
> > > http://www.st.com/internet/evalboard/product/252419.jsp
> > > http://www.embeddedartists.com/products/kits/lpc1788_kit.php
> > > http://www.embeddedartists.com/products/kits/lpc2478_kit.php
> > > http://www.embeddedartists.com/products/kits/lpc3250_kit.php
> http://www.phytec.com/products/rdk/ARM-XScale/phyCORE-ARM9-LPC3250.html
> > > > And I intend to do 2 other works (customize a BSP for my own board
> > > > and
> > > > use a simulator) but they are not in priority.
> > > On ARM several BSPs run on a simulator. This one uses the ARMv7-M
> > > architecture:
> > > http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
> > > Sebastian Huber, embedded brains GmbH
> > > Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> > > Phone : +49 89 18 90 80 79-6
> > > Fax : +49 89 18 90 80 79-9
> > > E-Mail : sebastian.huber at embedded-brains.de
> > > PGP : Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120503/538dc3c2/attachment-0001.html>
