Supported ARM BSPs
Gedare Bloom
gedare at rtems.org
Thu May 3 14:31:30 UTC 2012
On Thu, May 3, 2012 at 8:48 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 05/03/2012 03:36 AM, Fered wrote:
> Hi;
> I repaete my question again:
>> Are all available BSPs in the following address?
>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm
Those are the BSP "families" in ARM. Each family can have one or more
specific BSP.
> And some other questions:
> I this page, we have lm3s69xx and stm32f4 but I don't see a folder for
> LPC17xx. Which folder points to LPC17xx?
> [joel at iceland libbsp]$ pwd
> /home/joel/rtems-4.11-work/rtems-testing/rtems/rtems/c/src/lib/libbsp
> [joel at iceland libbsp]$ find . -name "lpc1*.cfg"
> ./arm/lpc24xx/make/custom/lpc17xx_ea_ram.cfg
> ./arm/lpc24xx/make/custom/lpc17xx_ea_rom_int.cfg
As Joel showed by example, the specific BSPs are configured / named in
.cfg files. Look in those to see the BSP name that should be used
specifically.
> Is BSP for lm3s69xx works only on Qemu?
> This is one for Sebastian.
I believe that is the case.
> Thanks a lot for your answers.
>> Thank you.
>> Sebastian Huber wrote:
>> > On 30/04/12 05:50, Fered wrote:
>> > > The problem is which BSPs are actually available?!
>> > If you want to add a new BSP, please use the Git master:
>> > The list on the wiki refers to the BSPs available on the Git master.
>> > > I want to buy a board and I'm not sure which board has a BSP
>> > > (whithout
>> > > modification or any additional attempt!).
>> > http://www.st.com/internet/evalboard/product/252419.jsp
>> > http://www.embeddedartists.com/products/kits/lpc1788_kit.php
>> > http://www.embeddedartists.com/products/kits/lpc2478_kit.php
>> > http://www.embeddedartists.com/products/kits/lpc3250_kit.php
>> > http://www.phytec.com/products/rdk/ARM-XScale/phyCORE-ARM9-LPC3250.html
>> > > And I intend to do 2 other works (customize a BSP for my own board
>> > > and
>> > > use a simulator) but they are not in priority.
>> > On ARM several BSPs run on a simulator. This one uses the ARMv7-M
>> > architecture:
>> > http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> > Phone : +49 89 18 90 80 79-6
>> > Fax : +49 89 18 90 80 79-9
>> > E-Mail : sebastian.huber at embedded-brains.de
>> > PGP : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
