Running lm3s6965 BSP on Qemu
Hesham Moustafa
heshamelmatary at gmail.com
Sat May 5 17:25:22 UTC 2012
I git pull the specified patches
and then run
make c/lm3s6965/testsuites/samples/hello
qemu-system-arm -S -s -net none -nographic -M lm3s6965evb -kernel hello.exe
but i got that only and nothing happens
"Warning: nic stellaris_enet.0 has no peer "
On Sat, May 5, 2012 at 6:20 PM, Hesham Moustafa <heshamelmatary at gmail.com>wrote:
> I have tried the patches in the qemu source and the script but it works
> for normal qemu command line , not qemu-system-arm , when i edited it to be
> qemu-system-arm it output an error " kernel image must be specified " , So
> i get qemu-system-arm to work manually through the rtems-boot.img and wrote
> some options like set root (hd0,0)
> multiboot ....... and specified the hello.exe but i got an error " address
> 0x0 is out of range "
> On Sat, May 5, 2012 at 5:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>> There are patches for qemu in the bsp source directory. I am not sure but
>> seriously doubt if those are in any pre-packaged qemu binary. I am not even
>> sure if they have been merged by qemu. Sebastian should know that.
>> Grab the qemu source, check if the patches apply and build you own.
>> How are invoking qemu?
>> Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>> >I am trying to get lm3s6965 BSP to work on Qemu .
>> >I followed some instruction in a Wiki page but in vain .
>> >It would be great if some one give me DEFINITE INSTRUCTIONS to get it
>> >work . I have fedora 16 with latest qemu-system-arm command line .
>> >thanks,
>> >Hesham
URL: <http://lists.rtems.org/pipermail/users/attachments/20120505/63a4b73b/attachment-0001.html>
