Running lm3s6965 BSP on Qemu
Sat May 5 17:53:57 UTC 2012
On Sat, May 5, 2012 at 1:25 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> I git pull the specified patches
> and then run
> make c/lm3s6965/testsuites/samples/hello
> qemu-system-arm -S -s -net none -nographic -M lm3s6965evb -kernel hello.exe
Try hello.bin
> but i got that only and nothing happens
> "Warning: nic stellaris_enet.0 has no peer "
> On Sat, May 5, 2012 at 6:20 PM, Hesham Moustafa <heshamelmatary at gmail.com>
> wrote:
>> I have tried the patches in the qemu source and the script but it works
>> for normal qemu command line , not qemu-system-arm , when i edited it to be
>> qemu-system-arm it output an error " kernel image must be specified " , So i
>> get qemu-system-arm to work manually through the rtems-boot.img and wrote
>> some options like set root (hd0,0)
>> multiboot ....... and specified the hello.exe but i got an error " address
>> 0x0 is out of range "
>> On Sat, May 5, 2012 at 5:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> There are patches for qemu in the bsp source directory. I am not sure but
>>> seriously doubt if those are in any pre-packaged qemu binary. I am not even
>>> sure if they have been merged by qemu. Sebastian should know that.
>>> Grab the qemu source, check if the patches apply and build you own.
>>> How are invoking qemu?
>>> Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>>> >I am trying to get lm3s6965 BSP to work on Qemu .
>>> >I followed some instruction in a Wiki page but in vain .
>>> >It would be great if some one give me DEFINITE INSTRUCTIONS to get it
>>> >work . I have fedora 16 with latest qemu-system-arm command line .
>>> >thanks,
>>> >Hesham
> rtems-users mailing list
> rtems-users at rtems.org
