TCP/IP packet fragmentation issue
Mick Davis
mickd at goanna.iinet.net.au
Mon May 21 04:10:49 UTC 2012
Hi
A patch for rtems 4.10 is attached. It implements the fix discussed in
the mailing list thread you reference. Writes a bit larger than MHLEN
(98 bytes I think) won't get fragmented, at least not in this socket
layer operation.
On 19/05/12 04:47, João Paulo Scalão Martins wrote:
> Hello friends, how are you doing?
> I'm working with a RTEMS-based system on a Single Board Computer,
> (Advantech PC104 - PCM 4153). The processor is the AMD Geode LX800. The
> system requires ethernet TCP/IP communication between the SBC and a
> Linux Destop. To implement this issues, I used the fxp driver (found in
> libbsdport library), because the network chip is the Intel 82551 ER.
> The software was written, and it all worked out in the initial tests.
> The communication between the SBC and the Linux (client) was efficient
> and stable. However, the TCP/IP packets changed were very small in size,
> 15 bytes. Our system can, eventually, send and receive packets of 250 or
> more bytes of data. I decided to do a test to see these situations.
> That's when the trouble began. I wrote several programs, some very
> simple (echo client-server), other more complex (four tasks), and all
> had the same problem of *_packet fragmentation_*. I analyzed the
> communication with a sniffer (Wireshark) and I will describe the
> observations:
> * As long as the data packets were smaller than 95 bytes, the
> connection was perfect. The period of one single iteration was about
> 150 microsseconds.
> * When the SBC-RTEMS needs to send more than 95 bytes, the data is
> fragmented on 2 frames. The first has *_96 bytes_*, and the second
> has the remaining. For the application level, this issue is
> transparent, BUT, between one frame and another, the elapsed time is
> about 40 milliseconds, whereas in the previous situation, it was
> about 150 microsseconds. Finally, the speed of the system dropped
> dramatically.
> o Detail: the second frame is sent only a few microsseconds after
> the client (Linux Desktop) sends an ACK packet.
> * When the stream of data is bigger than 200 bytes (I don't exactly
> this number) the system collapses. The SBC can even send the large
> packets in one frame, but after a few minutes, some retransmitions
> occurs (from both parts) and the connection undergoes a reset.
> I looked for a similar problem in the RTEMS mailing list, and found the
> following topic:
> http://www.rtems.com/ml/rtems-users/2004/june/msg00013.html
> But the numerical values are a bit different, and I didn't found the files.
> I apologize if maybe my problem is not related to RTEMS and is just a
> communication problem. However, we have done tests on the same hardware
> with other operating systems (Linux, NetBSD) and the communication was
> stable and efficient. Even with RTEMS, I made several types of
> programs, but the problem remained the same.
> Thanks for your help!
> Best regards from Brazil.
> Joao Paulo Martins
> */Brazilian Synchrotron Light Laboratory - LNLS <http://www.lnls.br>/*
> rtems-users mailing list
> rtems-users at rtems.org
Mick Davis
Goanna Technologies Pty Ltd
+61 8 9444 2634
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20120521/6091b47c/attachment-0001.bin>
