RES: TCP/IP packet fragmentation issue
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Wed May 30 13:57:01 UTC 2012
Hi João,
I'm curious on this issue. Have you applied the Mick's patch? Has it proved to be sufficient?
Please, give us a feedback when possible.
Thanks.
--Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Mick Davis
Enviada em: segunda-feira, 21 de maio de 2012 01:11
Para: João Paulo Scalão Martins
Cc: rtems-users at rtems.org
Assunto: Re: TCP/IP packet fragmentation issue
Hi
A patch for rtems 4.10 is attached. It implements the fix discussed in the mailing list thread you reference. Writes a bit larger than MHLEN
(98 bytes I think) won't get fragmented, at least not in this socket layer operation.
On 19/05/12 04:47, João Paulo Scalão Martins wrote:
> Hello friends, how are you doing?
> I'm working with a RTEMS-based system on a Single Board Computer,
> (Advantech PC104 - PCM 4153). The processor is the AMD Geode LX800.
> The system requires ethernet TCP/IP communication between the SBC and
> a Linux Destop. To implement this issues, I used the fxp driver (found
> in libbsdport library), because the network chip is the Intel 82551 ER.
> The software was written, and it all worked out in the initial tests.
> The communication between the SBC and the Linux (client) was efficient
> and stable. However, the TCP/IP packets changed were very small in
> size,
> 15 bytes. Our system can, eventually, send and receive packets of 250
> or more bytes of data. I decided to do a test to see these situations.
> That's when the trouble began. I wrote several programs, some very
> simple (echo client-server), other more complex (four tasks), and all
> had the same problem of *_packet fragmentation_*. I analyzed the
> communication with a sniffer (Wireshark) and I will describe the
> observations:
> * As long as the data packets were smaller than 95 bytes, the
> connection was perfect. The period of one single iteration was about
> 150 microsseconds.
> * When the SBC-RTEMS needs to send more than 95 bytes, the data is
> fragmented on 2 frames. The first has *_96 bytes_*, and the second
> has the remaining. For the application level, this issue is
> transparent, BUT, between one frame and another, the elapsed time is
> about 40 milliseconds, whereas in the previous situation, it was
> about 150 microsseconds. Finally, the speed of the system dropped
> dramatically.
> o Detail: the second frame is sent only a few microsseconds after
> the client (Linux Desktop) sends an ACK packet.
> * When the stream of data is bigger than 200 bytes (I don't exactly
> this number) the system collapses. The SBC can even send the large
> packets in one frame, but after a few minutes, some retransmitions
> occurs (from both parts) and the connection undergoes a reset.
> I looked for a similar problem in the RTEMS mailing list, and found
> the following topic:
> http://www.rtems.com/ml/rtems-users/2004/june/msg00013.html
> But the numerical values are a bit different, and I didn't found the files.
> I apologize if maybe my problem is not related to RTEMS and is just a
> communication problem. However, we have done tests on the same
> hardware with other operating systems (Linux, NetBSD) and the
> communication was stable and efficient. Even with RTEMS, I made
> several types of programs, but the problem remained the same.
> Thanks for your help!
> Best regards from Brazil.
> Joao Paulo Martins
> */Brazilian Synchrotron Light Laboratory - LNLS <http://www.lnls.br>/*
> rtems-users mailing list
Mick Davis
Goanna Technologies Pty Ltd
+61 8 9444 2634
