Debugging an RTEMS Application, show threads in gdb possible
Mon Nov 12 11:29:24 UTC 2012
Hello,
I cannot say much to the GDB support since I mainly use the Lauterbach
debugger, but there is some GDB support mentioned here:
http://www.rtems.org/wiki/index.php/GDB_Python
You can also start the RTEMS shell and use the "task", "sema", "cpuuse", etc.
commands to figure out the system state.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
