rtems C++ template
Luca Cinquepalmi
cinquepalmi at planetek.it
Mon Nov 12 17:04:45 UTC 2012
I did it, in fact I'm able to compile my source code without any errors.
The problem is that when I load it on my board no output is sent.
The same code, written in C perfectly works on board... so I think it
could depends
form the C++ template or form some Makefile flags... what do you think
about?
On 11/12/2012 05:54 PM, Sebastian Huber wrote:
> On 11/12/2012 05:04 PM, Luca Cinquepalmi wrote:
>> Hi all,
>> I'm try to compile a simple C++ code and make it work on a target
>> board (leon2
>> CPU) from some weeks, but no results nowaday... Can anybody send me a
>> simple
>> working rtems C++ code, also a simple printf, and the relative
>> Makefile so I
>> can compare it with mine? Thanks a lot for your help.
> You can configure RTEMS with the options "--enable-tests=samples" and
> "--enable-cxx". This will generate the cxx_iostream.exe and
> rtems++.exe as C++ sample applications. See also testsuites/samples.
